Author Topic: 4000 watt turbine  (Read 1381 times)
billf
4000 watt turbine
« on: July 07, 2004, 11:02:16 AM »
Don't know if it's been posted here, but here is the link to Hugh's prototype 4kw mill. Four thousand watts at 220 rpm. Wow.
http://homepages.enterprise.net/hugh0piggott/nirvana/index.htm
« Last Edit: July 07, 2004, 11:02:16 AM by (unknown) »
BrianK
Re: 4000 watt turbine
« Reply #1 on: July 07, 2004, 03:44:04 PM »
very nice looking machine if it won't bother you I told my girlfriend that it looks like even santa claus uses wind power. Not trying to be rude Just thought the pics were very neat
« Last Edit: July 07, 2004, 03:44:04 PM by BrianK »
JW
  • Development Manager
    • Flashsteam.com
« Reply #2 on: July 07, 2004, 08:00:45 PM »
This is a very cool post.
 I look at that stator, and say to myself, there must be atleast 500ft of thick a## copper wire in there. It amasazes me that a 24 volt circuit generazation schedule does not "overheat" at 4000watts. Iam convinced you could very well get 4000watts from a smaller diameter stator at 12vdc with water cooled windings. The question becomes, can less torgue generate sufficiant amps to drive a 4000watt circuit, with the 9/12 arrangement. The larger diameter stators, have more holding force, at the same ampere's capacity. Finsawer?/ I agree that this could lend itself, to low speed furling charictors of large rotor("ie" 15ft dia rotor-sets). but the feature of more wiring being naturally used, in a given diameter of stator, just lends itself to more circut, per volume per phase, what I mean is this- the 3 to 4 ratio(coil to magnet) acts as a function of inverese fractil, even, in Hugh's design of this circiut. What concerns me, is the seeming use of series-parallel design, in the "star circuit". With water cooling and a delta configuration, low speed amps should be thoretically possible. Further-more "the" phase alignment acuracy, in the 9/12 (9coils to 12magnets with dual rotor=24magnets)configuration, lends itself to the possible efficiency's. What really stumps me, is that larger diameters are more condusive to phases that are out of phase (sync) by 360* degree's, versa the 120*spacing of the 912 coil-to-magnet phase arrangement.
-JW
« Last Edit: July 07, 2004, 08:00:45 PM by JW »
JW
    • Flashsteam.com
« Reply #3 on: July 08, 2004, 08:18:29 AM »
I am just fasinated with these dual rotor designs, it seems the configuration possiblites are endless. My uncle was at one time helping a freind who was working with a neat savinous design. They could get the thing to spin all day with a light wind. problems arose when they tried to couple an auto alternator to the turbine, they lost alot thru the mechanical drive for the alt. The turbine was over 10ft in diameter. I think about these dual rotor genny's and think to myself, if they would have only known.
JW
« Last Edit: July 08, 2004, 08:18:29 AM by JW »
Nando
« Reply #4 on: July 13, 2004, 10:29:38 AM »
Jw:
Can you please translate what you said here
Nando
« Last Edit: July 13, 2004, 10:29:38 AM by Nando »
nack
« Reply #5 on: July 20, 2004, 06:18:41 PM »
Help me out here... how can a sine wave be 360 degrees out of phase?
« Last Edit: July 20, 2004, 06:18:41 PM by nack »
