Author Topic: My 3 Ph 1/2 hp motor convert works  (Read 1230 times)
ibedonc
« on: August 02, 2004, 11:47:59 PM »
follow up from here
http://www.fieldlines.com/story/2004/7/28/152439/834
this was my first one , used my lathe to slot the rotor to fit the Neo's list in previous story , grouped them 4 norths and 4 souths 3 north poles 3 south poles , matched the coils perfect , only a small amount of clogging and at 500 rpm on my lathe one ph puts out 75 volts and lights a 67 watt bulb (that is all I had ) I wired it for 230 volt
Jerry , do you think 4 of your 5 ft blades would be enough and do I need bigger
« Last Edit: August 02, 2004, 11:47:59 PM by (unknown) »
Re: My 3 Ph 1/2 hp motor convert works
« Reply #1 on: August 03, 2004, 02:01:20 AM »
you might want to toss those little 8amp rectifiers--your alt. will most likly
fry them under a good load..50 amp rectifiers cost only a couple bucks--and
theres  a hole in the center to mount them on a heat sink...glad to hear you
POWERED UP.............
« Last Edit: August 03, 2004, 02:01:20 AM by hiker »
« Reply #2 on: August 03, 2004, 03:14:34 AM »
sorry this should have gone to arc,
« Last Edit: August 03, 2004, 03:14:34 AM by hiker »
OFF TOPIC
« Reply #3 on: August 03, 2004, 09:02:14 AM »
Hey, ADMIN;
Do me a huge favor and shorten that intro line with the html in it it messes up the fp for me and I have to scroll sideways to see the boxes on this laptop.
Thanks.
T
« Last Edit: August 03, 2004, 09:02:14 AM by TomW »
Jessum Dumguy
Re: OFF TOPIC
« Reply #4 on: August 03, 2004, 11:49:24 AM »
It's not just you and your laptop TomW, I've been trying to
figure out what I'VE screwed up in my settings to cause it...
Sorry you got problems but I'm acctually glad someone
else does this time.  It's not me !!!
Jessum
« Last Edit: August 03, 2004, 11:49:24 AM by Jessum Dumguy »
arc
« Reply #5 on: August 03, 2004, 01:09:27 PM »
Hi WILD IN ALASKA,
I will order some higher amperage bridge rectifiers online.
I picked these up from Radio Shack for bench testing, they had some 25A ones too, but they were more expensive and not exactly what I was looking for.
One of my concerns is the Voltage Drop, so I hope to find a happy medium that will do the job but still work well under low wind conditions.
Got any good links for places to look online?
Thanks for the suggestion,
arc
« Last Edit: August 03, 2004, 01:09:27 PM by arc »
