You dont say where you are, but in the UK, you would connect to the 11 kv local distribution network. 690 v is the internal voltage of the turbine, and would be stepped up to 11 kv by a transformer in the base of the turbine. Local distribution voltage varies from country to country, so you will have to find out the local situation. Vestas should know.
Before spending significant money, make preliminary planning enquiries, and determine if your local grid connection is strong enough to take the power from your turbine. If you need long power lines, the cost of installation goes up.
You could also see if there is any local or national turbine owners association where you live, as in the initial stages, enthusiastic owners may offer you free advise on the processes involved in developing your project. This is far better than asking basic questions of a consultant who may charge you several hundred dollars an hour for his answers.
