Author Topic: PVC pipe prop - profile query  (Read 2362 times)
domwild
« on: February 01, 2005, 08:27:18 AM »
Please let me know what you think of these three
similar profiles. Mainly two questions:
1. I suppose I should have taken more material off the outer
side for the trailing edge, I chose the inner side.
2. The leading edge can be rounder (blunt) or less blunt -
any suggestions??
Thanks.
« Last Edit: February 01, 2005, 08:27:18 AM by (unknown) »
Re: PVC pipe prop - profile query
« Reply #1 on: February 01, 2005, 01:42:03 AM »
As these type blades are only suitable for low tsr I suspect that they will all be fine.
Any of the leading edges will do well but if you want the best possible chance I would thin the trailing edge on the inside from nearer the centre say 60% back from  LE and run it out to a sharp edge. Don't remove any from the outside, they are very cambered already.
They ought to perform well if you get the pitch right, you will have to set them at less an angle than normal carved wooden blades because of the camber.
« Last Edit: February 01, 2005, 01:42:03 AM by Flux »
bobn
« Reply #2 on: February 01, 2005, 02:38:38 AM »
 Generally the broader the leading edge radius the broader the range of angle of attack the blade will perform at or the less likely it will be to stall at high angles of attack.
Here is a common cambered airfoil.  a google serch will tell you about its characteristics.
http://www.anotherpower.com/gallery/energy-stuff-and-more/goe417a
BobN
« Last Edit: February 01, 2005, 02:38:38 AM by bobn »
picmacmillan
« Reply #3 on: February 01, 2005, 09:20:13 AM »
just an idea...would it be possible to heat the pvc, so as to shape it to what you need?...we used to heat plastic in an oven and when it became warm we would put it into a little jig we made and created ashtrays, or candy dishes....i just thought maybe you could maipulate the shape this way...pickster
« Last Edit: February 01, 2005, 09:20:13 AM by picmacmillan »
Dan M
« Reply #4 on: February 01, 2005, 09:21:56 AM »
Based on intuition, and a few other profiles I've seen, I like the leading edge of the bottom one, and the trailing edge of the top one.
For what it's worth.
Also, what diameter are you dealing with?  I've been scrounging all over for some large dia to play with and keep coming up dry (unless I want to buy it new).
-Dan M
« Last Edit: February 01, 2005, 09:21:56 AM by Dan M »
domwild
« Reply #5 on: February 02, 2005, 06:28:21 PM »
Thanks for all the help. The concensus is that a well-rounded leading edge
is best and a sharp trailing edge which starts in the inner chamber
 (concave side) and ends in a sharp trailing edge.
Very useful was the reference to these profiles, which confirms the
member's statements:
GOE497
NACA6409
Selig 1223
Clark Y
GOE417A
Thanks for the reference to these profiles. They all seem to be similar
to the ones the very first bi- and triplanes used.
All are doubly-chamfered profiles which approximate a pipe profile.
I have found offcuts of uPVC or PVC sewer and mains water pipe.
235mm to 250mm outside dia. with a wall size of 9mm to 12mm.
So we are looking for 9"-10" pipe with 3/8" to 1/2" wall for
all you "imperial" boys.
I am not saying this is optimal; just what one can find.
Full-length pipe would be too expensive.
It has been said that a 3m (10') dia. prop, four blades can even turn
a cogging F&P.
« Last Edit: February 02, 2005, 06:28:21 PM by domwild »
domwild
« Reply #6 on: February 02, 2005, 06:31:53 PM »
Thanks for that. It will probably need a long and narrow oven to heat it to just the correct plasticity.
Great web site.
« Last Edit: February 02, 2005, 06:31:53 PM by domwild »
« Reply #7 on: February 03, 2005, 08:36:55 AM »
Special 'electric blankets' just for this sort of thing can be purchased.
« Last Edit: February 03, 2005, 08:36:55 AM by ghurd »
« Reply #8 on: February 03, 2005, 07:29:20 PM »
« Last Edit: February 03, 2005, 07:29:20 PM by wooferhound »
domwild
« Reply #9 on: February 05, 2005, 07:57:01 PM »
Thanks Wooferhound. I am just wondering how much less efficiency one gets
with this leading and trailing edge, which is that much easier to make.
It just means setting the jig saw to 45 deg. and to try to cut radially.
The profile data bases and the members all seem to say the leading edge should
be rounded.
« Last Edit: February 05, 2005, 07:57:01 PM by domwild »
