Oil sucks, wind blows.
you wouldn't believe that one extra nut on one of the studs was all it needed to balance the blades. Allthough I painstakingly sanded each blade to make them the same weight.
Reinforced my stator brackets
The box with all the wiring and heatsink in a good position for coolingback viewThe blade tracking is only 13mm out (I'm happy with this much)It needs more coats of Linseed oil, but I'm waiting for it to dry.Our house and solar array that the PMA will assist.
Richard
rich
Do you have some more info on the setup? Is it island or grid-intertied?
I think the Homepower magazine would be quite happy with a story from you. (www.homepower.com)
They are 80 watt each 24 panels (1920kW) so nearly I guess.They put out over 80 volts with about 25 amps in good sun.
"I think the Homepower magazine would be quite happy with a story from you. (www.homepower.com)"
I would be glad to give one.
We are not on grid power here the nearest pole is about 2 k's away.The inverter is a Siemens 2kVA inverter/charger/booster backed up with a 4kVA diesel generator all automated.8 6volt century yuasa 535 amp/hr batteries.
