OK i just saw the file from Soutwest Windpower's website.
It seems that you need to change the turbine´s stator, either for 24 or 48 volts, then remove the jumper from the control circuit. SWWP allows you to use the electronics for different voltage set-ups. I'm guessing the stator is pretty cheap but the electronics aren't. If your turbine is 12 volts the circuit can operate @ 24v after removing the jumper, but it won't work for a 36 or 48v turbine.
In all cases you need a new stator.
Good Luck,
Warrior
