Howdy Marck,
PVC is a great way to make rotor blades rapidly. they are good for medium term testing, but their lifespan is very limited.
My own experience, in this very windy area, is that these blades will last from 4 to 10 months.
I tried strengthening them by stacking 2 more levels of blade material behind the rotor. The finished product looked very much like the leaf springs of a car. In addition, I added a diagonal brace that went from the rear of the 3/4 inch rotor hub to a point that was 70% of the blade's length from the hub's periphery.
This extended the lifespan of the rotor to 18 months.
Eventually the 1.8 metre rotor began failing again. As the tips would 'flutter' at high speeds, they were prone to breakage.
The worst failure mode could be seen at the roots of the blades where cracks would form.
Given time, these would proceed across the blade's width and cause spectacular failures during storms.
My 'record' so far for 'blade hurling', is 210 metres. Not bad eh?
Sometimes, it can take a while to find all the pieces .
To bring things up to date, I replaced these ill fated blades with Aluminium ones. They are 2 years old now, and functioning perfectly.
They have survived storms that have torn roofs off houses, so I have high hopes for these .
Hope this helps.
Cheers,
Steve Mc Amptramp.
