Well here's what I got going today.
Was flying a 4 pole 1/4hp motor conversion, rotor was cut flat and 4 disk magnets on it, it was making power but not that great, but it was working fine as set up.
I just pulled out the rotor today and put in one that is turned down and has 4 of the #29 type arcs on it.
OK, just open volts here, but with flat rotor and disk neos spining with fingers got around 30Vac on any 2 wires out of 3. With ARCS finger spinning about same speed open volts around 50-60Vac any 2 wires of 3. Arcs appeared to double open AC volts at least, alittle more cogging than the flats and a touch harder to turn.
I would have tested on the lathe and used the rpm meter etc.. but I was on the roof and just changed out the rotor up there.
Well OK I know now I got open volts and it works, so I connect the same wires back up same way to the genny and run power into the house where I can play with batteries and DC volts.
First off I notice the genny is not spinning when I connected the wires on the roof, and I had mild winds, it should been turning. I come into the house, remove the battery and the genny takes off like a jet, Pole is bolted to house so I can hear it running. I like it noisy that way for testing, If I can't look out and see it I can at least hear it. Jerry blades are quite it's the genny rumble I can hear.
Wow, meter shows I was getting around 100Vdc and more open volts. I connect the battery and the genny stops like slaming on the brakes at yellow light that just turned red ![Sad :(](https://www.fieldlines.com/Smileys/default/sad.gif)
No I am certian I am not just stalling out blades here, it does not coast to a stop, it stops like shorting wires to shut it down! The Jerry blades work well even though I have a setup in a turbulent spot. They over come the cogging I have very easily also.
I have taken all the wires off the bridge rectifiers, using any 2 wires and either bridge has the same effect. Really good open DC volts, brakes to a stop if connecting a battery! I get good readings for DC open volts from each bridge so am prety sure that bad rectifier is not a problem.
The AC wires are on the AC termials, and the POS terminal is on the Bat pos and the neg on the neg. I don't see any shorts to shut it down?
I was using about a 17amp hour SLA 12V, I started to wire up a 24V set and a 48V set to see if the same thing would happen but that is when my wind stopped today.
