Author Topic: Yaw bearing  (Read 1564 times)
jmk
Yaw bearing
« on: April 15, 2006, 05:46:51 PM »
 I polished the the tower top and the inside of the yaw pipe so it would fit on with no play. I cut a 1" piece of yaw pipe and welded it to the tower, so when sliding the yaw pipe on it will stop when it hits the collar. I put a grease fitting in the yaw pipe. The tower goes all the way trough, and then sticks up about 11/2". The part that sticks up I drilled and taped a set screw. I am putting the tower on a big mogal of a hill, and it may lean down hill a bit. I didn't want the turbine to fall of. I cut anouther piece of yaw pipe 11/2" and welded it to the top of the yaw bearing with about 11/2" gap inbetween. This will leave room for the head of the set screw. Above that I plan on puting a removeable aluminum funel to route the wires down. Will this work? What are your opinions?
« Last Edit: April 15, 2006, 05:46:51 PM by (unknown) »
jmk
Re: Yaw bearing
« Reply #1 on: April 15, 2006, 12:48:31 PM »
 Here are some pictures.
« Last Edit: April 15, 2006, 12:48:31 PM by jmk »
Walt
Re: Yaw bearing
« Reply #2 on: April 15, 2006, 04:49:12 PM »
JMK
Your generator looks really good. One think that you mentioned that your tower will not be totally vertical, that will be a problem. Your mill will not face into the wind and even if it will it won't furl properly. Having the pivot bearing on the bottom shouldn't be a problem I though IMO.
What is the diameter of your magnet rotor and what diameter are your blades?
Keep up the good work.
Walt
« Last Edit: April 15, 2006, 04:49:12 PM by Walt »
Walt
Re: Yaw bearing
« Reply #3 on: April 15, 2006, 04:57:16 PM »
Forget the question, I should have looked at your other post.
Walt
« Last Edit: April 15, 2006, 04:57:16 PM by Walt »
jmk
Re: Yaw bearing
« Reply #4 on: April 15, 2006, 08:18:14 PM »
 It will stand plumb when it is up. When I tilt it down to the ground I was first thinking it would be laying down hill. Now I think the hill will be ok if I tilt it down and stop when it is level. This will leave the rotor about 8' in the air. This way the blades and tail wont touch the ground. I am still glad I put the set screw in. I think the collar at the bottom will help hold the grease in. I wonder if I put wax at the bottom if it will even hold the grease in better?
« Last Edit: April 15, 2006, 08:18:14 PM by jmk »
jmk
Re: Yaw bearing
« Reply #5 on: April 15, 2006, 10:36:22 PM »
a couple more pics
« Last Edit: April 15, 2006, 10:36:22 PM by jmk »
