Author Topic: Small wind turbine - need help with choosing a motor  (Read 739 times)
fzn10
« on: May 08, 2006, 10:25:23 AM »
Im using a bicycle dynamo for a project that i have, the propeller will only rotate at 100RPM in whihc my dynamo only gives out 1Vp-p, this is really bad cause i cant do much with kind of voltage, do you guys know of any other motor devices that would give a higher voltage(between 5-10V), at this rpm. I also want the device to be as fricitoneless as possible.
« Last Edit: May 08, 2006, 10:25:23 AM by (unknown) »
drdongle
Re: Small wind turbine -
« Reply #1 on: May 08, 2006, 05:30:38 AM »
Us the boards Search funtion and look for "tape drive motor"
« Last Edit: May 08, 2006, 05:30:38 AM by drdongle »
