Hello,
You said the average wind speed is 9.5mph. Be careful about that. Where I live the average afternoon wind speed is about 13mph but it's in the tops of trees 60 feet high. On the roof of my house 25 feet high there is almost no wind at all, even when the tops of trees in my neighborhood are bending over. Before you jump headlong into a wind turbine ask yourself for where you live do you have the ability to erect a tower tall enough to get your turbine up into the wind? I have both solar panels and a wind turbine. The solar panels produce about 90% of my RE power because tall trees in my neighborhood block the wind and I can't build a tower tall enough to get above them.
Also, the 9.5mph average, is that the afternoon wind speed when the wind is strongest for a few hours a day? Or is it the 24 hour average? My guess is it's the average "peak" wind. Most of the time (in 24 hour day) I bet your wind speed is between zero and 5mph. If that is the case your turbine will be producing nothing most of the time. Even at 9.5mph you will get very little if anything at all. Most small wind turbines don't start producing much power until the wind gets to about 15mph or more. How many hours a day do you get that?
Like I said, I have both solar panels and wind turbine. The turbine gives me 90% of the fun working on it but the solar panels give my 90% of my RE energy. You may want to consider spending your money on solar panels first.
Also, unless you really get serious about RE I agree with a previous comment about feeding power back to the grid, forget it. Instead isolate the appliances that can be powered via RE such as computers, consumer electronics, lamps, etc. and power them independently with RE disconnected from the grid.
Good luck,
Rob
