Dear folks,
in an attempt to fabricate a axial flux alternator i've glued two times 18 `toy' magnets (NbFeBo 20x20x3 mm M45) on 1 mm steel discs. The magnets love it On second thought i could have placed the magnets a bit further to the edge increasing the spacing between them.
When i tried out assembling with the magnets on it -- before coating it with polyester epoxy -- the forces were that unexpectedly big since they boost each other a lot that it buckled the two steel discs to each other until they touched Only the spacer area was still flat :-|
Breaking them apart was hard but with some effort i managed. The magnets were still fine though one had had such a big pull on it that it separated from its nickel coating and detached! The others are fine.
I wonder what to do... flattening them again was no problem but Will coating the discs with a 3-4 mm polyester resin all the way including the center (no hole in the middle) provide enough stiffness? Shall i use the glass fiber mat covering the magnets method Hugh advises? or should i (also) try something else? I wouldn't like to see the polyester crack up and the plates ruined again, maybe for good this time.
I hope waxing the three m6 bolts will keep them out of the resin since i wanted to double them as lid fixings.
Any advice and help would be much appreciated!
Thanks in advance,
Reinoud
