Author Topic: Grid Connecting a Homebrew Turbine  (Read 1277 times)
cec
« on: July 14, 2006, 05:48:56 PM »
Hello,
We are building a 500W Hugh Piggot design turbine. I'd like to use it without a battery bank, and was hoping that a product like SMA's Windy Boy might do the trick.  Has anyone had any luck doing this?
Thanks,
Christian
« Last Edit: July 14, 2006, 05:48:56 PM by (unknown) »
QUAZ HOLT
Re: Grid Connecting a Homebrew Turbine
« Reply #1 on: July 14, 2006, 02:20:32 PM »
Cec, Buy the inverter and sent it to me. I will check it out for you. MR W.
« Last Edit: July 14, 2006, 02:20:32 PM by QUAZ HOLT »
amiklic1
« Reply #2 on: July 14, 2006, 02:37:24 PM »
Just downlod the WindyBoy manual and other documents from their site (SMA America) and you'll find all the info you need. It's very good explained about the working voltges, when it connects....
Just read it "from cover to cover"
« Last Edit: July 14, 2006, 02:37:24 PM by amiklic1 »
Phil Timmons
« Reply #3 on: July 14, 2006, 02:46:18 PM »
QUAZ, I am thinking ordering a Russian Mail Order bride.  Can I send her to your place, so you can check her out before I get her?  Thanks, buddy, we are all in this together, you know. :) :)
Serious note to cec -- we use the Sunny Boys (solar), and they are pretty much plug and play.  The Windy Boys are supposed to just be wind friendly versions of the Sunny Boys, but I have not used one, yet.  But the Windy Boys come with a WHOLE lot of notes and cavaets in the connection cautions part of the manual -- that sort of assume you are using a commercial windmill with protective hardware and devices.  You probably need to read and understand those details quite well.
« Last Edit: July 14, 2006, 02:46:18 PM by Phil Timmons »
cec
« Reply #4 on: July 14, 2006, 04:39:49 PM »
Are you serious?  If so, who are you and how will you check it out?  What sort of things might need to be modified (i.e. what would be the difference between my machine and Proven or Bergey) ,and would it be possible that I could make the modification myself?  Do you know of other options for wind grid tie inverters?
Thanks, CEC
« Last Edit: July 14, 2006, 04:39:49 PM by cec »
RP
« Reply #5 on: July 14, 2006, 08:17:52 PM »
QUAZ was joking of course
« Last Edit: July 14, 2006, 08:17:52 PM by RP »
paradigmdesign
« Reply #6 on: July 18, 2006, 09:42:23 AM »
I belive that in the States, your turbine along with the inverter must be UL certified, allong with an inspection by the electric company.  They will also probiblly need to install a meter that reads both directions, at a cost to you.
« Last Edit: July 18, 2006, 09:42:23 AM by paradigmdesign »
