Author Topic: Other Power wind parts specs.  (Read 947 times)
Dave B
    • DCB Energy Systems
« on: August 19, 2006, 04:07:50 PM »
I don't believe the thickness of the 12" steel rotor disks offered is listed on the alternator parts available. I am interested in possibly purchasing 2 and also wondered if any other sizes could be ordered and if so without any holes pre-drilled ? Thank you for your reply.  Dave B.
« Last Edit: August 19, 2006, 04:07:50 PM by (unknown) »
DCB Energy Systems
http://dcbenergy.com/
ADMIN
Re: Other Power wind parts specs.
« Reply #1 on: August 21, 2006, 07:42:12 AM »
Hi Dave!
The magnet rotor disks are 1/4 inch thick steel. They are CAD-cut, including the holes,  so we'd have to do a custom run for you to make them with no holes. Email us directly for a quote. You might also consider having a local metal shop cut them for you, it might be cheaper since it would be simple and they could do it with a simple circle-cutting jig on a plasma cutter.
ADMIN
« Last Edit: August 21, 2006, 07:42:12 AM by ADMIN »
kurt
    • website
« Reply #2 on: August 21, 2006, 12:57:57 PM »
you can get 1/4" thick disks here with no holes.
http://windstuffnow.com/main/builders_corner.htm
« Last Edit: August 21, 2006, 12:57:57 PM by kurt »
Dave B
« Reply #3 on: August 21, 2006, 05:03:35 PM »
Thank you for the information. I may use 3/4" thick magnets and figure I better go with 1/2" steel especially if I go with greater than 12" diameter besides. I've been spinning a 12' 3 blade single phase with laminants pre-heating water and plan to go with a dual rotor and probably an 18' 3 blade. This should be a better match for pre-heating water as the 12' has been more of an experiment to get the bugs out and test the application. The 85' tilt tower (shown) was more of a project than the alternator. Thanks again,  Dave B.
« Last Edit: August 21, 2006, 05:03:35 PM by Dave B »
DCB Energy Systems
