Author Topic: Zephyrus wind generator plans  (Read 2086 times)
eraser1
« on: February 27, 2007, 05:02:47 AM »
Does anyone have any info on the Zephyrus wind generator plans specs etc.
http://www.prismz.com/windpower/
thanks for any help
« Last Edit: February 27, 2007, 05:02:47 AM by (unknown) »
Warrior
  • Country: ar
Re: Zephyrus wind generator plans
« Reply #1 on: February 27, 2007, 05:04:51 AM »
It looks like an Entertech 1800 clone. Basically an induction grid tied machine.
Warrior
« Last Edit: February 27, 2007, 05:04:51 AM by Warrior »
Bigwheel
« Reply #2 on: April 15, 2007, 07:51:48 AM »
I too wound say that it is a clone of the Enertech 1500/1800.  Based on the plans that I have it states it is capiable of:
output voltage: 115v
maxium line voltage: 135v
minimum voltage at machine: 110v
max generating current: 26 amps
start up: 8mph
shut down: 45 mph
survival: 100 mph
blade length: 80 inches
2hp induction motor
(11.3/1) helical gear box
hydraulic brake assembly
Hope this helps you out, Just bought the plans to see what it needs to build it and over time aquire the necessary freebe parts.  I do like the way they layed out the blade making procedure in the manual.  It uses a series of oversize airfoil templets that you slide over your 2x8 lumber.  Set your router to the proper depth and run the router over the wood and then you have the contour.  If all the pieces were made might take 1/2 hour to whip one out and then it's ready for sanding.  Hope this help you out and if there are any more questions feel free to ask.
Chad
« Last Edit: April 15, 2007, 07:51:48 AM by Bigwheel »
