I'll throw out some comments for what they are worth...
'I have had some ideas bouncing around in my head for a 40' Tilt-up tower. My hope is that in the event of a cable failure, my tower will not immediatly come crashing to earth.'
I think it will - the base will not hold up the tower, especially a tower of fairly small (3") pipe.
'In strong winds, nothing will stop it, but I would like a chance to remedy the situation.'
I'd worry more about preventing a cable failure than hoping to build a base that will support a tiltup tower without cables on it.
'The tilt assembly is made from (2) 12" lengths of 10" C-Channel. The hinge is 2" schedule 40 pipe over 1 1/2" pipe. The 1 1/2" pipe acts as the hinge pin. The 2" pipe is cut into 2" lengths and welded to each of the C-Channels to form a hinge.'
The hinge looks workable although I prefer a looser hinge that gives a bit more slop side to side. We'll often use 3" pipe over 2" pipe or something. The hinge will not support your tower in any way - if the guy wires are off at all or it's inclined to go one side or the other, it'll just tear up the hinge, bend the tower, move the pad etc... I would rather have slop in the hinge. Not necessary if you get everything perfect though I suppose.
'Not shown in the pictures is the concrete base. Not exactly sure what to use here, but I was thinking about 18" x 18" square pad at least 36" deep. The pipe protruding horizontaly is a 4" length of 2 1/2" pipe that my 3" x 20' gin pole will slip over.'
That should be fine but I don't think a great concrete anchor at the base is that necessary. Again, the base is not going to hold the tower up on this sort of tower - the main purpose of the base is to keep it from sliding and keep it from sinking! So a wide shallow pad maybe more appropriate. We often just build a metal base and stake it down. If the tower works properly, all the forces should only be down on the base.
'The bolts holding the fixed C-Channel (Green) are 1"x8" long and have rebar welded in a cage assembly that can be buried in the wet concrete. The other two bolts are welded to the fixed C-Channel and will lock the pivot assembly once in the up position.
Also not shown is the rest of the tower. Basically (2) 21' lengths of 3" pipe with a threaded coupling. I will be using (2) 3/8" chain links, (1) welded to the pipe just below the coupling, (1) will pivot free and have the 1/4" cable looped through it. There will be a similar arrangement at about the 35' height.
'The cable anchors are going the be the screw-in earth anchors. I don't trust them screwed in the ground, so I will be digging holes and embedding them in a couple bags of concrete. I will be welding the loop closed and welding some extra junk to the buried part of the anchors. Seems like I saw someone slipping brake rotors over the anchor, what a swell idea.'
Should be reasonable if depending on the anchors and the earth.
'The plan at this time is to use one turnbuckle for both sets of cables. Maybe someone can talk me out of it, but I just spent $80 on (4) turnbuckles and I'm going broke. I can't belive how much $$ this thing is consuming.'
Maybe with equalizers but I'd have turnbuckles on each cable. I think it's worth the extra $80.
