Oil sucks, wind blows.
http://www.fieldlines.com/story/2006/5/23/231326/646http://www.fieldlines.com/story/2006/5/6/102016/2184http://www.fieldlines.com/story/2006/6/1/15401/37082http://www.fieldlines.com/story/2009/2/22/1783/83068http://www.fieldlines.com/story/2007/8/31/15347/9608http://www.fieldlines.com/story/2005/2/1/42930/30269http://www.fieldlines.com/story/2004/9/2/22724/72530http://www.fieldlines.com/story/2004/8/18/143839/578
Batdude
It's hard to get the scale there but that brass set is around 2.5 to 3 inches diameter if I remember correctly.
I did try to make my own but with a small lathe plus lack of experience and bar-stock I was struggling to make something that would fit over the scaffold tubing I use as a tower. I did however manage to bore out the set in the picture above to fit.
Given the correct grade of brush, adequate spring pressure and a weatherproof cover those type of rings will work well but they occasionally squeak when yawing about and it can be irritating.
A slip-former ? Trans-Ringer ?
Should be theoretically do-able...
boB
