Author Topic: Arghhhhh stoopid internet canna find dc brushless circuit  (Read 1291 times)
headhunter
« on: December 09, 2004, 01:51:44 AM »
Seriously, I've spent a couple hours trying to find a layout of how a dc brushless circuit works.  I've read lots of descriptions and understand how it works but as a visual person I still need to see it work.  Anyone know of any flash animations or animated gifs or even static representation of what's going on with the transistors and hall probe on a dc brushless motor??  Yep searched this site too...
Hopefully thanks in advance.
Ivan.
« Last Edit: December 09, 2004, 01:51:44 AM by (unknown) »
Peppyy
« Reply #1 on: December 08, 2004, 07:08:46 PM »
I can't seem to find any animations but here is a great site about dc and circut parts etc.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/dccircon.html#c1
« Last Edit: December 08, 2004, 07:08:46 PM by (unknown) »
RP
Re: Arghhhhh stoopid internet canna find dc brushl
« Reply #2 on: December 08, 2004, 08:55:44 PM »
Try this:
  [Animated gif
« Last Edit: December 08, 2004, 08:55:44 PM by (unknown) »
RP
« Reply #3 on: December 08, 2004, 08:58:42 PM »
Dohh!  New to html tag formatting.  Try this instead:
http://www.servomag.com/flash/4-pole/smi-motor-gif.htm
« Last Edit: December 08, 2004, 08:58:42 PM by (unknown) »
Roamer195
« Reply #4 on: December 09, 2004, 12:40:26 AM »
The simplest circuit just uses a hall-effect device to do the same job as a commutator would normally do.
In other words, put the hall-effect device across the collector-base connection on a transistor (darlington style).
Then the trsnsistor collector-emitter is connected in series with the DC source and the stator winding(s).
If I may ask, what are you planning to do with the motor?
« Last Edit: December 09, 2004, 12:40:26 AM by (unknown) »
Opera House
Re: brushless circuit
« Reply #5 on: December 09, 2004, 06:14:43 AM »
As they said in Firesign Theater, "Sometimes you can't tell the AC's from the DC's."  Rather than marking position and turning on a coil, many motor designs are just 2, 3 or more phases and are driven at a constant frequency. Basically AC motors.  No reason to put in sensors you don't have to.
« Last Edit: December 09, 2004, 06:14:43 AM by (unknown) »
