Author Topic: Voltage Controller  (Read 1323 times)
(unknown)
Voltage Controller
« on: December 12, 2007, 02:17:21 PM »
Having a background in electronics I would jump at the chance to build my own controller for my wind turbine (Ametek 30VDC). If anyone has info on kits please advise.
Moved to a more appropriate section.
« Last Edit: December 12, 2007, 02:17:21 PM by (unknown) »
  • Moderator
Re: Voltage Controller
« Reply #1 on: December 12, 2007, 07:55:35 AM »
Oatley has a kit.  Kind of expensive with shipping from AU.  More intended for 3-ph.
I have a kit intended for Ametek type stuff. Still $12.50 each, $3 S&H per order.
Still ghurd1 (at) yahoo (dot) com
http://www.fieldlines.com/story/2007/8/24/172521/889
« Last Edit: December 12, 2007, 07:55:35 AM by (unknown) »
Capt Slog
« Reply #2 on: December 12, 2007, 09:25:55 AM »
I have one of Ghurds.
It's neat, works well, and is expandable.  I know it's nice to make things for  yourself but at the price it's hardly worth the effort.  I don't have a great deal of electrical nounce, so being able to just put it together and then sit and look at the flashing light was very nice.
Diary entry here
http://www.fieldlines.com/story/2007/8/30/8538/81113
« Last Edit: December 12, 2007, 09:25:55 AM by (unknown) »
(unknown)
« Reply #3 on: December 12, 2007, 01:20:28 PM »
Ghurd,
Thanks for the info on your kit. I am slowly piecing to-gether my system and your kit is a valuable addition. Didn't mention in my previous post that I will be using a bank of 12vdc deep cycle batteries wired parallel. And, for a load I plan on a 12vdc 600w water heater element.
 I would like to purchase your kit. Please email me at rwa864@hotmail.com for shipping  and Paypal payment request.
« Last Edit: December 12, 2007, 01:20:28 PM by (unknown) »
wdyasq
« Reply #4 on: December 13, 2007, 06:59:15 AM »
WOW - a 600W dump load on an AMTEK....
I think I might find a load a little closer to the maximum out put of the generator.
Good luck,
« Last Edit: December 13, 2007, 06:59:15 AM by (unknown) »
  • Moderator
« Reply #5 on: December 13, 2007, 07:26:02 AM »
That's what I said!  That's in the C60 class.  Could do it with an IGBT.
Might be a good idea to use a 24V 600W water heater element, which will dump about 150W at 12V.
Easier to control. More heat in the water, less in the wire. Easier on the battery.
And cheaper!
« Last Edit: December 13, 2007, 07:26:02 AM by (unknown) »
(unknown)
« Reply #6 on: December 13, 2007, 05:53:07 PM »
Looks like I need a 24v heater element... where do I look for those in Can/US?
By the way, what is the average output for a Ametek 30vdc using (3) 32" pvc blades?
« Last Edit: December 13, 2007, 05:53:07 PM by (unknown) »
« Reply #7 on: December 14, 2007, 09:24:12 AM »
Hey Capt;
 And your's beats all the ones I've put together by a country mile:-)
How's it doing since installing it?
I will say that of the 4+ units I've assembeled and installed they're all doing just like they are suppsoed to. I've checked a few just to make sure they aren't getting off the set dump voltage and none have needed any "tweaking"
« Last Edit: December 14, 2007, 09:24:12 AM by (unknown) »
wdyasq
« Reply #8 on: December 14, 2007, 10:30:50 PM »
From the handy IRC wind power calculator:
389.9 watts possible from 2.5 ft dia prop (4.9 sq ft) in 25 mph wind (density of 1.225000),62.4 watts output assuming generator is 80% efficient and Cp of 0.20
That is with real blades, not PVC pipe blades.
« Last Edit: December 14, 2007, 10:30:50 PM by (unknown) »
