Author Topic: AC transformers  (Read 874 times)
Jason Wilkinson
  • Country: bb
AC transformers
« on: September 11, 2008, 05:13:04 AM »
 Hi to all,  i have two transformers, one gives 11.8 vac and the other 14.6 vac  open circuit  measured with the same voltmeter. when the 11.8 is connected to the batt  through the rectifier the current to the batt is 7 amps  if i interchange the 14.6 transformer the current to the batt is only 4 amps i have checked the voltage on both several times  and it's always the same i seem not to be able to understand why the smaller voltage gives the larger current. The 11.8  transformer is larger in size
 Jason
« Last Edit: September 11, 2008, 05:13:04 AM by (unknown) »
Re: AC transformers
« Reply #1 on: September 11, 2008, 01:18:35 AM »
"The 11.8  transformer is larger in size"
That is your answer. The large one has a lower impedance ( probably both resistance and reactance are lower).
« Last Edit: September 11, 2008, 01:18:35 AM by (unknown) »
Jason Wilkinson
  • Country: bb
Re: AC transformers
« Reply #2 on: September 11, 2008, 12:46:44 PM »
THanks again  FLUX
 jason
« Last Edit: September 11, 2008, 12:46:44 PM by (unknown) »
framistan
Re: AC transformers
« Reply #3 on: September 12, 2008, 07:53:05 PM »
The comment left by "flux" is correct,but i think this example will
help you understand what is happening.  If your battery was almost
fully charged, and only ONE amp flowed, then the higher voltage transformer
would deliver a little more amps than the lower voltage one.  .  However, since your example has a pretty well discharged battery, then the smaller transformer is delivering ALL THE AMPS it is capable of ( because like "flux" says, it is the
smaller)  However the larger transformer is capable of more AMPS.
Just like in ohms law .... the load determines how many amps will
flow.  In the real world, the quantity of amps delivered to the load
is determined by VOLTAGE of the source... and RESISTANCE of the load,
and also the CAPABILITY of the source.  consider the ohms-law problem of
12 volts going to a 2 ohm load.  6 amps will flow, because 12volts divided
by 2 ohms is 6 amps.  but only 2amps will flow if the REAL WORLD power
supply is only capable of delivering 2 amps! hope that helps.... framistan
« Last Edit: September 12, 2008, 07:53:05 PM by (unknown) »
