Author Topic: Pump controls pressure switch  (Read 2295 times)
adobejoe
« on: December 12, 2008, 01:54:05 AM »
Instead of using a float switch requiring 700 ft of wire, I want a pressure actuated switch to connect/disconnect the PV panel at the pump. The Pumptrol type differential switches might work, but I want a narrow lower and upper limit, like 20 psi upper, and 18 psi lower. Any ideas?Adobe Joe
« Last Edit: December 12, 2008, 01:54:05 AM by (unknown) »
David HK
  • Country: hk
Re: Pump controls pressure switch
« Reply #1 on: December 11, 2008, 09:33:46 PM »
Hello,
I have a brand new still in the box water pressure switch which I do not require.
The technical specs are in this PDF file
http://cn.siemens.com/cms/cn/English/SBT/downloading/HVAC_Product_Home/Pressure_Sensor/Documents/Ser
ies%20Pressure%20Sensor/1.pdf
I live in Hong Kong.
If its what you want I can send it airmail on the basis of a Christmas present for somone else in the world. People in this forum do help each other.
David HK
« Last Edit: December 11, 2008, 09:33:46 PM by (unknown) »
David HK
  • Country: hk
« Reply #2 on: December 11, 2008, 09:37:55 PM »
For clarity this switch measuring range is from 0 to 10 bar; Output signal DC 0 to 10V; operating voltage 24v AC(?) re-check the spec for operating voltage.
David HK
« Last Edit: December 11, 2008, 09:37:55 PM by (unknown) »
Simen
  • Country: no
  • Grimstad, Norway
« Reply #3 on: December 12, 2008, 01:53:02 AM »
A cheap alternative might be a pressure switch found in washing machines. They also have (often) 2 and 3 separate levels, all adjustable on and off pressures. Though they are meant for low pressures... (5-10psi?)
I myself are using one of these in my wooden boat as a automatic bilge-switch; connected via a thin hose to a small bellhouse (upper half of a plastic sodabottle, where the hose are fastened in the cork) in the bottom of the bilge. It has worked flawless for 2 years now.
« Last Edit: December 12, 2008, 01:53:02 AM by (unknown) »
adobejoe
« Reply #4 on: December 12, 2008, 07:36:11 AM »
DavidHK,
Very generous of you, but I do not think this will work. It requires 24 V AC.  All I have is 12 V DC from solar panel. What I think I need is  purely mechanical switch that opens/closes contacts. That will then control (connect) the solar PV panel to complete a circuit. My pressure range is 38 ft (18 psi) cut in or turn on and 46 ft (20 psi cout out or turn off. The washing machine switch is a good idea, but too low pressures.
Adobe Joe
« Last Edit: December 12, 2008, 07:36:11 AM by (unknown) »
  • Moderator
« Reply #5 on: December 12, 2008, 09:57:32 AM »
Maybe look some of the simple old types.
I used to have to mess with a well system that often became water logged.
It was a spring (reminds me of a cheap wall thermostat) and 2 adjusting screws.
One screw set the On pressure, other set the Off.
Been a long LONG time, but I don't see why it couldn't have been adjusted pretty tight.
« Last Edit: December 12, 2008, 09:57:32 AM by (unknown) »
Simen
  • Country: no
  • Grimstad, Norway
« Reply #6 on: December 12, 2008, 12:26:55 PM »
I'm just guessing the psi those washing machine pressure switches operates at; it's possible they can be adjusted much higher. Point is that you can probably get them for free at the junkyard... ;) Wouldn't hurt test one. :)
Those Ghurd are talking about are very similar in function. Offhand, equipment that use them that i can think of would be heating elements for swimming pools etc.
« Last Edit: December 12, 2008, 12:26:55 PM by (unknown) »
tanner0441
« Reply #7 on: December 12, 2008, 01:05:22 PM »
hi
Have you thought of a standard No-Float switch, electronic level controler, rectify the AC at the pump 3 stainless probes long common, short upper level, medium lower level.
Also electronic bilge pump switches, just a block with 2 stainless strips round it with a timer so the pump continues for 10 seconds after the to strip is exposed.. 12 to 36 V again rectify at the pump.
Brian.
« Last Edit: December 12, 2008, 01:05:22 PM by (unknown) »
adobejoe
« Reply #8 on: December 12, 2008, 05:31:42 PM »
There is no AC at the pump, it is a 12 V DC submersible and a 12 Volt Kyocero PV panel. I htink the best is some type of diaphragm type mechanical switch...will keep looking.Adobe joe
« Last Edit: December 12, 2008, 05:31:42 PM by (unknown) »
alcul8r
« Reply #9 on: December 13, 2008, 06:43:46 PM »
Digi-key is not cooperating with my dial-up right now, but I'll bet you could find a pressure transducer in the right range with either 20 ma or 0-5v output, use a comparator against a 10-turn pot and be all set.
« Last Edit: December 13, 2008, 06:43:46 PM by (unknown) »
cyplesma
« Reply #10 on: December 17, 2008, 05:46:01 PM »
for an AC switch use a small 100 watt inverter.
« Last Edit: December 17, 2008, 05:46:01 PM by (unknown) »
cyplesma
« Reply #11 on: December 17, 2008, 05:54:55 PM »
« Last Edit: December 17, 2008, 05:54:55 PM by (unknown) »
