Author Topic: Heres a link to the Trade Wind meter.  (Read 3078 times)
« on: November 24, 2009, 06:36:31 PM »
http://www.dimatewashington.edu/TradeWind.html
This might work DANO? There is a story of these old anemometers and pictures here.
« Last Edit: November 24, 2009, 06:36:31 PM by (unknown) »
Re: Heres a link to the Trade Wind meter.
« Reply #1 on: November 25, 2009, 02:19:29 AM »
Jerry;
That link does not work for me?
Maybe post it again in case you copied it wrong?
« Last Edit: November 25, 2009, 02:19:29 AM by (unknown) »
« Last Edit: November 25, 2009, 06:22:47 AM by (unknown) »
« Reply #3 on: November 25, 2009, 08:26:49 AM »
Thanks willib, Thanks Tom.
I had made a post about the meters befor I posted the link. The first post went missing, never showed up.
So I'll repete the original as best I can remember?
I found the A1 meter at the Goodwill store. It was $5. I've been searching the net trying to find an analog anemometer with no luck.
Then I hapened onto this meter part of the Trade Winds anemometer but the sensore part was not there.
As the link says, Trade Winds simpy used a small brush type PM dc motor to power the wind gage meter direct, no other electronics.
I know there is a DIY version on the OP projects page but I want to do this the same way T-W did it.
I'm real anoid at the 5 second delay on my Oregon Scientific and another comercial unit I have.
I want the direct instant reading the old analog unit can provide.
I'm thinking of using a small 3 phase brushless motor from a hard drive or equal.
Will there be a scaling or voltage curve problem with this diferant type motor.
I do have the cup set part, from our hosts.
I'll try to calibrate it against the Oregon Scientific in my wind tunnel.
Any ideas.
« Last Edit: November 25, 2009, 08:26:49 AM by (unknown) »
tanner0441
« Reply #4 on: November 25, 2009, 09:44:03 AM »
Hi
I made a unit a few years ago using a head drum motor from an old video player. I used the output from the motor not the opto coupler on the base of the thing, I fed it directly into an old chart recorder for an instant but permanent record. I was living in a coastal reading in North Wales UK and recorded just over 90MPH. I calibrated it by enlisting a friend an stuffed it out of the car window on a pole.
I balanced it to the display with a 1K trimmer.  I went for the head drum motor because the bearings were realy robust, I made the cups from the tops of deodorant cans and the legs were bits of brazing wire epoxied to an old pulley that fitted the shaft.
Brian.
« Last Edit: November 25, 2009, 09:44:03 AM by (unknown) »
  • Moderator
« Reply #5 on: November 25, 2009, 09:56:50 AM »
I don't think you will get very good results with a 1A DC meter and a HD motor.
They have to get going pretty fast before they get past the rectifier losses.
Might do better with a HD (or maybe a DLT drive) motor, 2 phases connected to an AC volt meter with a full scale swing of about 5V.
« Last Edit: November 25, 2009, 09:56:50 AM by (unknown) »
Stonebrain
« Reply #6 on: November 25, 2009, 01:17:35 PM »
I think best is to build a microgenerator,so you can adapt the number of turns of the coils to any nicelooking voltmeter(to be found on ebay).
A condition is that the generator must be more powerfull than the needs of the meter.
As far as I understand electricity,that meanz that the resistance of the generator must be much lower than that of the meter(am I right?).
cheers,
stonebrain
« Last Edit: November 25, 2009, 01:17:35 PM by (unknown) »
« Reply #7 on: November 25, 2009, 05:36:22 PM »
I checked the meter movment coil directly. It measures 210 ohms.
Through a 1k pot I found that a full scale reading equals 40 millivolt accross the coil.  (.0040)volt I used a 1.5 volt D cell for the DC source.
I think this will work fine with a hard drive or VCR head drum motor. The 1k pot should work for calibration. I may have to increase the pot value?
I'll post results when in.
Thanks guys.
« Last Edit: November 25, 2009, 05:36:22 PM by (unknown) »
« Reply #8 on: November 25, 2009, 06:58:11 PM »
Analog meters and separate sensors are still sold here:
http://www.kansaswindpower.net/wind_instruments.htm
« Last Edit: November 25, 2009, 06:58:11 PM by (unknown) »
