Author Topic: gs electric treadmill motor  (Read 8061 times)
dollarbwoi
« on: July 08, 2010, 10:49:55 PM »
I got a permanet dc magnet motor, a gs electric and was wonderin if it can be used as a wind generator.
Motor specs
120VDC
2.5HP
5600 rpm
Re: gs electric treadmill motor
« Reply #1 on: July 08, 2010, 11:04:41 PM »
It will make 12 volts at 560rpm
it will charge a battery to 14.4 volts at 672 rpm
http://fieldlines.com/board/index.php/topic,143574.0.html
« Last Edit: July 08, 2010, 11:07:01 PM by wooferhound »
dollarbwoi
« Reply #2 on: July 08, 2010, 11:19:40 PM »
Isnt that rpm to fast to charge a battery, if it can be used what blade design would i need?
« Reply #3 on: July 09, 2010, 01:58:02 AM »
 Four in series in a good wind area works .I know where you are .  Wanting to get some things together to get started on a system . I started with solar . A little at a time to get some batteries and put them in place to get an idea of the power I could replace on grid . I haven't done too bad I still shop for batteries much the same as I did then . Batteries plus has t 105s and 108s for 100 bucks and I buy them with extra money . Solar is mixed in with the wind and I could go on but those original project have given way to a method to make real world grid energy deductions .yada yada .
 That Three or four volt average needs some other units  if you have the room ; or you need to rethink your start . You might just spend some time charting the wind in your area . Do  you have modest tree flagging ? Is the good wind at 20 or 50 feet in elevation? Things like that with Betz in mind is a good start . Don't get frustrated by this unit .
dollarbwoi
« Reply #4 on: July 09, 2010, 02:14:28 AM »
I live the caribbean, jamaica and where am at is very windy sometimes. I live in a two story house, so i was gnna put the windmill on top. Has anyone used this motor for wind turbine?
zap
  • There's an app for that
« Reply #5 on: July 09, 2010, 10:22:30 AM »
Expect some noise to be transmitted into the house if you mount it on the roof.
Here's a youtube video, not the exact motor, higher rpm but also a higher voltage... GS electric-130VDC-6700RPM-18Amps
http://www.youtube.com/watch?v=olxeXGonOIk
http://www.youtube.com/watch?v=fbwVgQ52LoM
Try it and let us know the results.
« Reply #6 on: July 10, 2010, 08:34:12 AM »
Not good enough for a single turbine is the consciousness .
dollarbwoi
« Reply #7 on: July 10, 2010, 11:09:32 AM »
Any gearing system recommended for this motor?
« Reply #8 on: July 10, 2010, 01:41:51 PM »
Bicycle crank is about right 4 to 1 is good you should be able bolt a cassette sprocket on the fly wheel of the motor and the crank sproket to a blade hub.Use grease  on the chain and make a cover for the mech . Fashion and idler for the chain  and set it on a tilt up tower for adjustments .
taylorp035
« Reply #9 on: July 10, 2010, 11:10:18 PM »
I think 672 rpm is not achievable under normal circumstances.  But since you have the motor, if you really want some power, you will need to gear it up.  It would not be easy, especially for your first windmill.  Maybe a set of small 4' diameter might get you close on a windy day.
Good luck!
Harold in CR
« Reply #10 on: July 11, 2010, 09:00:40 AM »
 I just recently bought an inline Helical gear, 10"1 ratio gear reducer, on ebay.  Paid $50.00. It's like new but has been used. My son will buy an extra set of seals, before it gets down here.
  I have started the hub system for the governing blade, but, I am way backed up with Furniture orders, so, I'm going slow on the project.
  I might use the governed hub on my Treadmill motor, that is 90V-20 Amp rated @ 3100 RPM. I plan to make a set of 4' long blades, giving me an 8'5" span.
  Might change generators, to get more watts at lower voltage.
  I will do up a Diary build when I get to work on the system in earnest.
dollarbwoi
« Reply #11 on: July 11, 2010, 05:29:03 PM »
When the motor was spun with my hand i got 3-4VOLTS, with that in mind i thought it generate at least 13v at the wind.
Harold in CR
« Reply #12 on: July 11, 2010, 06:13:45 PM »
 It probably will. Mine won't get above 6.7 volts, in an 11.4 MPH wind. Mine is only 13' off the ground, and surrounded by house, bushes and trees. I know it needs to go up to 45'+, but, I'm watching for balance problems, especially as it yaws, very quickly. So far, all is well.
  When I pull it down, I will document the Anemometer I built for less than $22.00. Works well, even in the sheltered area.
« Reply #13 on: July 12, 2010, 12:17:06 AM »
You might nug 12 volts at 500to 600 rpm  but your not going to hit 600 rpm and drive any current after cut the motor is  just out of range .
dollarbwoi
« Reply #14 on: July 12, 2010, 08:00:33 PM »
Anyone knows if the 1N4007 diode can be used as blocking diode for my wind turbine?
« Reply #15 on: July 12, 2010, 09:39:46 PM »
a 1N4007 diode is 1 amp at 1000 volts
