Author Topic: Power Controller  (Read 1441 times)
zander1976
Power Controller
« on: July 20, 2010, 09:17:53 PM »
Hello,
I have been looking at wind turbine engines and I am in over my head again. I am slowly getting a grasp on solar power but now I am lost again with wind turbine. From what I can tell from solar I need to pick a voltage but with wind the voltage quickly goes out of control. How do I integrate a wind generator into an inverter with voltage ranging from 10 volts to 100 or so volts. Is there a way to convert voltage into current and reduce the voltage down to a 12 volt setup. Or do I just have a controller dumping load above 12 volts.
Thanks,
Ben
zander1976
Re: Power Controller
« Reply #1 on: July 20, 2010, 09:19:11 PM »
ps. I am working on VAWT.. :)
Tritium
« Reply #2 on: July 20, 2010, 11:02:37 PM »
You need a battery which by its nature will clamp the voltage to 12V nominal until it is full then you need a dump load controller (see ghurd controller) to get rid of the extra power from the battery to an auxiliary load of some sort (usually a resistor array as heat).
Thurmond
