Today I had a look at the tapered bearing spec's and the front bearing which will take the radial load will handle 970ftlb and the rear bearing that takes the axial load will handle just over 2,000ftlb's. I am going to get Timken bearings as Russian front ones were supplied and hopefully it will handle the load I'll be putting on. The main reason I asked the question is from looking at other hubs guys have used the front bearing looked a heap bigger than the one on my hub.
Cheers Bryan
