Author Topic: expert opinion  (Read 2213 times)
zoo1
expert opinion
« on: June 07, 2011, 02:07:40 PM »
Hello friends!
I have a question about the stator. Following are the description of my rotor.
1: 12inch diameter of rotor plate 12 N42 2in length 1in widths ¼ thick.
2: 12 neo magnets (I don't know about grade) 2in long 1.2inch width 10mm thick other side of rotor.
3: I have #22, #18, #16 gauge wire.
I made my test coil with all of them
360 turns per coil with #22 = 2.5vac, resistance of coil is 1.9ohm.
205 turns per coil with #18 = 2vac, resistance of coil is 1.5ohm.
106 turns per coil with #16 = 1.5vac resistance of coil is 1ohm
I want to make more than 500 watt wind turbine @ 150 rpm cut-in rpm round about 180.
Please suggest me a perfect gauge wire for amps and number of turns for volts.  Estimate for me what I should need to do with them to make a turbine
jlt
Re: expert opinion
« Reply #1 on: June 08, 2011, 01:01:14 PM »
The 16 gauge would be about right .for a 200rpm cut in. and 7ft blade.You would need larger mags to go bigger.
zvizdic
Re: expert opinion
« Reply #2 on: June 08, 2011, 10:35:37 PM »
Voltage you aiming for???????????
zoo1
Re: expert opinion
« Reply #3 on: June 09, 2011, 06:52:34 AM »
12v for round about 500watt
Re: expert opinion
« Reply #4 on: June 09, 2011, 07:20:16 AM »
What speed did you use to get your test coil results?  It is not obvious from your post so I don't want to jump to conclusions.
zvizdic
Re: expert opinion
« Reply #5 on: June 09, 2011, 04:38:59 PM »
Air gap ?
Coil thickens ?
One thing is clear you need #16 wire two in hand if you are able to reach 40A with magnets you haw.
