Author Topic: Slip rings for wind turbines  (Read 4996 times)
Bio Diesel Man
« on: March 06, 2012, 04:10:53 PM »
Has anyone come up with a reliable design for wind turbine slip rings so you don"t have to worry about the lead wires coming down the tower getting twisted and possibly failing??  Any pictures and input would be great..  Thanks, Duff  Bio Diesel Man
cdog
Re: Slip rings for wind turbines
« Reply #1 on: March 06, 2012, 04:13:38 PM »
Ive had mine up almost four years without issue.....but many here will shoot me for advising them lol!
rossw
« Reply #2 on: March 06, 2012, 04:43:38 PM »
I wouldn't (shoot you) - my 1kW machine went up 23/Feb/2006 and is still running fine, sliprings and all. Thats 6 years so far and no sign of distress either.
cdog
« Reply #3 on: March 06, 2012, 05:19:26 PM »
I had pics up on the old board.....not sure if they made it here.......?
cdog
« Reply #4 on: March 06, 2012, 06:42:59 PM »
I think a guy named "mitcamp" maybe is where i got the basic idea.....
JW
  • Development Manager
    • Flashsteam.com
« Reply #5 on: March 06, 2012, 06:52:52 PM »
Ive been working to locate things like this, here's what I have-
http://www.fieldlines.com/index.php?topic=144033.0
http://www.fieldlines.com/index.php?topic=137967.0
Some of the info made it thru ok, but the stuff that didnt we are finding...
cdog
« Reply #6 on: March 06, 2012, 07:01:54 PM »
Thats the one....mine is nearly identical except i had three rings and run the ac down the tower..
This has been an absolute bomb proof outfit!
cdog
« Reply #7 on: March 06, 2012, 07:03:53 PM »
Actually....mine has brushes opposing each other with threaded rod and a coil spring for tension....so i have two brushes per ring...
JW
    • Flashsteam.com
« Reply #8 on: March 06, 2012, 07:13:32 PM »
I was thinking about the 3 slip-ring pictures when I started my search.
Its entirly possible I maybe able to find your pics,
Give me some key words, well see what we find (title of thread etc)
JW
    • Flashsteam.com
« Reply #9 on: March 06, 2012, 07:16:56 PM »
cdog
« Reply #10 on: March 06, 2012, 07:18:37 PM »
No...
Dan just mailed me the link.....jm only on my cell....not sure if i can share....perhaps he added them to my profile...not sure...
JW
    • Flashsteam.com
« Reply #11 on: March 06, 2012, 07:32:37 PM »
Here's somemore of Mitcamp's stuff-
http://www.fieldlines.com/index.php?topic=140613.0
Cdog I can probably help make your link work, if the URL starts with "board.fieldlines" there is a workaround im using. This error makes the page go to the index of the board, anything posted in that timeframe has this directory error, post the link here, "even if it points to the "index page.
« Last Edit: March 06, 2012, 07:34:23 PM by JW »
cdog
« Reply #12 on: March 06, 2012, 07:35:05 PM »
Could dan perhaps send you what he sent me?
I cant seem to do this from my cell sorry...
cdog
« Reply #13 on: March 06, 2012, 07:38:07 PM »
Check your inbox i think i just forwarded dans mail to you....
cdog
« Reply #14 on: March 06, 2012, 07:39:31 PM »
"2084" would be a good one......
JW
    • Flashsteam.com
« Reply #15 on: March 06, 2012, 07:44:04 PM »
DanG did a great job on research here-
  < slip rings
http://www.otherpower.com/images/scimages/4506/  <--- your image directory
here's 2084
« Last Edit: March 06, 2012, 07:45:35 PM by JW »
cdog
« Reply #16 on: March 06, 2012, 07:45:53 PM »
Perfect!
Many thanks to both!
zvizdic
« Reply #17 on: March 06, 2012, 07:55:01 PM »
My slip ring at a bottom of a tower for easy access 2 years no problem hope to stay that way.
It is nylon housing with brass rings and fingers ,spring loaded ,pact  with silicone grease(electrical).
Inside shaft runs on 2 bearings so it is ease to turn even trough is not spinning a lot, cable absorbs some twist.
Going to 48v allows you to use smaller slip rings and .My brass on brass setup works good and not damaging rings or fingers .
« Last Edit: March 06, 2012, 08:07:35 PM by zvizdic »
nekit
« Reply #18 on: March 06, 2012, 09:13:18 PM »
I've got slip rings from a farm pivot irrigator.  You might be able to find a used one from a farm irrigator company, lots of them here in the midwest.  Rated at 600VAC and high amps.  You can see pictures in my "User Diary";  "My 17' So Far"
JW
    • Flashsteam.com
« Reply #19 on: March 06, 2012, 09:33:13 PM »
Quote from: nekit
http://www.fieldlines.com/index.php?topic=144309.0
« Last Edit: March 06, 2012, 09:35:27 PM by JW »
