Author Topic: New Project, CNC Router  (Read 8740 times)
Boondocker
« on: December 07, 2012, 07:16:05 PM »
Some photos on building a CNC Router
First made a torsion table top.
80/20 is used for the frame construction
Boondocker
Re: New Project, CNC Router
« Reply #1 on: December 07, 2012, 07:19:35 PM »
Boondocker
« Reply #2 on: December 07, 2012, 07:22:04 PM »
Obtain the design and most of the parts from:
http://www.cncrouterparts.com/
birdhouse
  • Portland, OR USA
« Reply #3 on: December 07, 2012, 10:31:30 PM »
that's awesome!  nice work.  i like the old school wooden base table design.  what profile is that in the last picture?
what is the max length you can do?
adam
Boondocker
« Reply #4 on: December 08, 2012, 05:48:05 AM »
Birdhouse,
The torsion box table makes a very solid, flat foundation to support the machine.
Can carve/cut just over seven feet long.  The table top is 4'x8', to give you a sense of scale.
The photo is a 222GOE profile with a tapper and twist.  Practicing on small pieces to learn first. No prior CNC experience.
Boondocker
Frank S
« Reply #5 on: December 08, 2012, 06:47:57 AM »
Very nice superbly done
 And a great link I have an old Victor Magnetic tracing torch that I built a 4 by 12  burn table for and a gantry for the torch I could use many of these items they offer to convert the gantry system to CNC then add a torch to the back side  I would then have a CNC burn table with Magnetic tracing ability that would be great
« Reply #6 on: December 08, 2012, 04:36:58 PM »
Nice! If anyone needs plastic shapes I have a laser cutter. Up to about 18x10 inches can be cut and 1/2 inch thick. Cut edges will have a taper, nature of the beast with beam spread.
Frank S
« Reply #7 on: December 08, 2012, 07:22:40 PM »
Actually I need to find a good laser for steel or SS up to 1/2" thick to put in place of one of my planetary Ox Gas torches That burn rig already has a Hypertherm 2000 plasma and 2 Ox /Gas torches all set up 3 axis and 9 straight line ox /gas torches on the back of the gantry
 replacing one of the front ox/ gas torches with a laser would both speed up and add higher precision cutting for super thin materials
« Reply #8 on: December 09, 2012, 03:25:43 PM »
My 60 watt CO2 won't even mark steel or metal, have to use a dye process to engrave even. Get into metal cutting and it makes my CO2 laser look cheap!
Boondocker
« Reply #9 on: December 11, 2012, 07:03:15 PM »
Carved out a 5ft blade demo out of foam.  It took about 1 1/2hr per side using a 1/4" endmill.  Use Qblade program to design the blade export it as a *.stl file.
Watching the CNC carve out a blade is almost as fun watching your turbine spin :)
« Reply #10 on: April 20, 2013, 02:43:02 PM »
I think I'm going to join you  in this . I've been wanting to hookup a new direction to what I can do here and this is what .
« Reply #11 on: April 20, 2013, 05:50:23 PM »
Just one of the reasons that keeps bringing us back to FL.  Sharing ideas inspires the rest of us.
