Author Topic: Passive Pitch control  (Read 3079 times)
adindia08
  • Country: in
« on: January 29, 2015, 01:22:06 AM »
Hi all ...I am a newbie to this site. There is a lot information getting exchanged on this forum. I am trying to design a 5 kW wind turbine and I need help in putting a passive pitch control mechanism. Unable to get any specification or dimensions.  :-[ Need help.
kitestrings
Re: Passive Pitch control
« Reply #1 on: January 29, 2015, 10:08:42 AM »
Welcome.
There's quite a bit of information on furling (folding tail) designs, if you google that here.  It's passive and fairly simple (in concept anyway).  Or, pick up one Hugh Piggot, or Dan Bartman's books on homebuilt turbines.
If you mean blade pitch, there is also some discussion on that here as well.  Well not passive, midwoud1 (Frans) has done quite a lot with pitch control:
http://www.fieldlines.com/index.php/topic,145925.msg995189.html#msg995189
~ks
midwoud1
« Reply #2 on: January 30, 2015, 04:40:01 PM »
Welcome.
I have an active pitch controlled windgenerator.
 wind > active pitchcontrol > midwoud1
https://www.google.nl/search?q=windgenerator+passive+pitchcontrol&rlz=1T4MERD_enNL505NL505&source=lnms&tbm=isch&sa=X&ei=tfTLVIrxL8nFPZfYgOAO&ved=0CAgQ_AUoAQ&biw=981&bih=432&dpr=1.3
On google images ,click  you can find alot of info passive and active pitch.
Rgds. FB.  Mw1.
« Reply #3 on: February 01, 2015, 06:54:38 PM »
Many photos exchanged on this thread (despite some old ones that are now lost)
http://www.fieldlines.com/index.php/topic,138013.27.html
Including the passive pitch-control that Frans started with!
adindia08
  • Country: in
« Reply #4 on: February 03, 2015, 01:18:24 AM »
Hi all ,
thanks for your suggestions. Although some stuff is there ..but i dont have material to start with. Can anyone help with specifications or dimensions data.
midwoud1
« Reply #5 on: February 03, 2015, 07:57:52 AM »
adindia
If this is your first diy windturbine, the best info is like Kitestrings said , the books of Hugh Piggott or Dan Bartman .
There you have all the dimensions and materials you need.
Clear explanation how to build .
Furling tail windmills , Later make a passive control hub on it.
@ Sparweb . I lost videos on Youtube by a mistake, pushed a wrong button.
                   New upload will follow.
Fb Mw1
TDC
« Reply #6 on: February 03, 2015, 07:56:06 PM »
I think most experienced builders would consider that very good advice.  As a newbie, I bought two of Hugh Piggot's books and spent a huge amount of time reading this forum the last few weeks. Quite an education!    http://scoraigwind.co.uk/      http://www.otherpower.com/20page1.html   http://www.amazon.com/dp/0981920101/ref=cm_sw_su_dp#customerReviews
« Last Edit: February 03, 2015, 08:06:25 PM by TDC »
