Time flies when your having fun, well so the story goes I am told. Truth be told life itself gets in the way of our doing the things we feel we should be doing.
in the past month just that has been happening I had several vehicles that I needed to do some work on to get them out of my way.
A couple of trailers that had air leaks in the brake systems, Swapping around the steering tires on the Mack since it was going back on the road and no longer needed the over width steering tires for driving around in a field on a solar farm project.
I got one of my expeditions running the Dodge 2500 transmission done and its gone the red Suburban is gone and I got the 2500 Chevy transmission working without having to pull it so it is gone the only vehicles left in the shop is my 93F350 that I need to pull the transmission and rebuild it but that will have to wait a while , and a f150 that I need to section in a new rear frame section and a new bed mount to make it safe to be driven but that is a back burner project just now in the mean time it works just fine as storage and to move things around on the place.
So I started getting a few things done to the North side of the shop I want to get the North and the South sealed in before fall.
Since I am all about using materials on hand when ever possible and saving my new stock for later I decided to weld together some of the old 2" diameter round purlin tubes from the old building I tore down for materials to build this shop with.
I am insulating with the 3" thick PIR freezer insulation panels it has a high R value plus being closed cell it is also self extinguishing and will not support flame
Working my way around after getting the wall to the 8 ft high mark instead of setting up scaffold or dragging the bus scaffold around.
I decided it was a good time to get the stairs and landings in place to gain access to the bus on top of the JB hunt container
Just needs a few girts and it will be ready for a floor
step landings in place I will use angle iron for the risers and tread supports
But now that I have used up all of my 4" sq tubing except for a couple of very short pieces and some new sticks with 3/8" wall thickness
I needed to come up with something else for the stringers. For these I decided to use the side rails off of the upper deck that I cut off a trailer to use the frame as the base for the brick crane I think it is no more than fitting that these wind up as part of the building as well
