Author Topic: nickel-zinc rechargeable AA and AAA cells  (Read 4154 times)
« on: August 28, 2019, 07:43:08 PM »
Does anyone here use these of recent manufacture? The design is old, but I am told PowerGenix has made construction/design changes that make them less fragile. I have 8 wireless thermostats that eat alkaline AA's and I don't think NiMH will work well, as the units report low bat near 1.2v
https://www.tomsguide.com/us/rechargeable-batteries-cell,review-1525-3.html reported the higher voltage burned out flashlights and the cells are slightly bigger than a regular AA, so they may not fit. I have also read there is no H2 O2 recombiner, so they cannot be safely left on a maintenance charge. But the capacity is high and the voltage is much better for certain things like cameras.
MagnetJuice
Re: nickel-zinc rechargeable AA and AAA cells
« Reply #1 on: August 28, 2019, 09:40:21 PM »
That article in tomsguide.com is over 10 years old. The company that made these batteries was http://www.powergenix.com
That website no longer exists, it redirects to https://www.zincfive.com
Most likely, it is the same company. The smallest battery they have are Sub-C. I didn't find anyone that sells the individual cells, only in UPS and possible very large quantities. Nevertheless, it is an interesting formulation.
Ed
MagnetJuice
« Reply #2 on: August 29, 2019, 11:41:57 AM »
Another option for you is to use Rechargeable Alkaline; they have a higher voltage than NiMH. It all depends on what is cheaper and more convenient.
I have been recharging regular alkaline batteries for many years without a problem. To charge the regular alkaline, I modified a charger that was used to charge Rechargeable alkaline. The trick is to feed them the right voltage and charge them before they get below 1.45 volts.
I try hard to find ways to save a little money because I have three kids with all kinds of electronic toys.
Ed
« Reply #3 on: August 29, 2019, 05:44:27 PM »
Ed
Interesting but no price anywhere and nobody selling them online...
MagnetJuice
« Reply #5 on: August 30, 2019, 06:52:27 PM »
I was more interested in that 80A/H battery they have..
« Reply #6 on: September 19, 2019, 08:41:37 PM »
I got 8 AA cells and a dedicated charger from China today. They are high voltage for a AA. Over 1.8v charged. From China they came in 1.72v
I have some AA NiMH high capacity cells that are 1.35v charged, so I took one of each and the combined voltage is just under 3.2v Two AA alkalines fresh have that voltage. The single 3.2v LiFePO4 with dummy cell in a wireless wall thermostat was down to about 1/4 charge after almost 3 weeks, so I swapped them out for a NiMH and NiZn set and will report back when that set gets low. They should last a while. The NiMH is rated 2.5 ah, just like the NiZn, but I don't believe the NiMH rating. That's too close to the theoretical physical limit for that sixze cell and chemistry.
