A Permogator is a permanent magnet motor generator/alternator contraption. My wife penned the name and I think it's appropriate. So much for that.
Permogator I
This is a prototype test platform. The idea is to see if it's possible to extract the energy of permanent magnets for a useful purpose. Not that this hasn't ever been done. In this case, the useful purpose will be to spin a disc and generate some electricity simultaneously, then compare the electricity generated against the electricity used and obtain an effeciency factor.
The induction coils are about 50 turns of 20 AWG magnet wire. Eight are used for the motor and eight for the generator, sandwiching eight 1/2 diameter by 1/4 thick neo magnets. Power to the motor section is supplied with four AA batteries through a 555 chip set up to pulse. Two potentiometers are used to control the pulse rate and duration. The coils are connected in series top and bottom.
Here is a side view of the machine, which is machined plexiglas.
And here is the plan.
Initially, the unit requires a manual spin to get it going. An early test of the apparatus ran for 13 hours before the 2000 mAhr batteries discharged to the point they would no activate the chip. I have been unable to duplicate that time since, however have acheived 11 hours and now that I've used ball bearings on the shaft, I get 9 hours regularly (go figure). I am assuming 8000 mAhrs used per test and comparing the output at 5,6 in mAs times the hours of operations to see how they compare.
I don't know exactly what is happening, but here are the readings I get with the multimeter.
Power on.
At 1,2 the volts are 5.2 and ohms here are 13,700; Amps .0038
At 3,4 the volts are .62 DC .378 mV AC and ohms here are 1.4 Hmmm. I don't know what is going on here at this time.
At 5,6 the volts are 0 and the ohms here are 1.4
Spin the disc up. I don't have a tach, but counting the ticks per second, leads me to think I'm getting something like 500 to 600 RPMs. That is a lot more than I thought, based on the 555 chip specs which indicate 3 Hz at .33 Duty. Anyway, the spinning disc reaches an equilibrium and doesn't vary much, despite manipulation of the 20k pots.
Power on, disc spinning at ~500 RPM
At 1.2 the volts are 5.2; Amps .0038
At 3.4 the volts are 1.3; Amps .99
At 5,6 the volts are 1.09; Amps .78
This goes on for 9 hours but voltage tails off at 1,2. Finally I think it used 8000 mAhrs and generated 7007 mAhrs. 88% effecient it looks like to me.
But I'm pretty new at this and circuit analysis is pretty baffling sometimes.
I am posting here, as a rank amateur, hoping for some feed back from the many experts that frequent this board. If I were able to duplicate that 13 hour run, it seems like this contraption is extracting more power than it used? Is that promising enough to go on to Permogater II?
