Author Topic: software & jig  (Read 937 times)
jacquesm
software & jig
« on: September 20, 2004, 07:44:49 PM »
Today (and yesterday) I worked on a proper jig to allow the foam to be placed with reproducible accuracy. Easier said than done, but I think I have it now. A ladder like structure with pins that poke into the foam, and a hard '0' point to reset the router in case I get lost and to verify that I didn't lose any steps (my table is a cheapie, I don't have a feedback mechanism on there).
Also the hard '0' gives me a repeatable Z '0', so it works for all dimensions.
After welding it up I placed it on the table and clamped it with some wedges to level it.
Then I spent hours and hours on tuning the toolpath for the blade run. It took
4 hours before to get one side done, now it's down to 1:36 or so. That should keep the router a lot happier too.
My new ball bit finally arrived.
Tomorow I'll be doing the next test run, I still have one more billet that I made up like that last one, good enough to test with. Then we'll try something radically different.
« Last Edit: September 20, 2004, 07:44:49 PM by (unknown) »
JF
Re: software & jig
« Reply #1 on: September 21, 2004, 01:59:48 PM »
Dear Jacquesm
After reading your diary with interest and especially noting your progress with hot foam and routers, I also noted you in common with many others had a problem with blade visualization.
Some time ago Virtanen sent in a file to the previous discussion board that I had put together on this subject that may perhaps be of interest to you.
If you cannot find this file in the archives - post your mail address and I'll send you a copy.
Greetings - JF
« Last Edit: September 21, 2004, 01:59:48 PM by JF »
jacquesm
Re: software & jig
« Reply #2 on: October 13, 2004, 07:48:57 PM »
my email address is in my signature, but just in case, it's j@ww.com , you have to put the current password which is 'stjoes' somewhere in the text to get past the whitelist.
thanks !
« Last Edit: October 13, 2004, 07:48:57 PM by jacquesm »
