Author Topic: Cool little rechargable flashlights  (Read 1243 times)
wildbill hickup
« on: December 07, 2004, 01:41:29 PM »
Don't throw out those battery packs when the phone says there no good!!!! Some time back I had a problem with keeping the battery charged on my Nokia 232 cell phone. I went on ebay and bid on a replacement battery (I think I got it for $3.00.) When I recieved the new pack I put it in the phone, charged it for 24 and presto! Dead battery. I calle3d and they sent me another it worked fine end of story right? Wrong!! Being the type that won't throw anything out unless all possabilities of salvage have been exhausted I took the pack apart and found 3 AA NiMH bateries inside in series and when I tested them with a VM 4.5v+, but the phone registered them as being dead. I made up a 5000mcd LED and a resistor circuit and hooked it up, LED lights, left it for 4 days LED still lit. Well this is good so I added a small switch I had laying around bent the wires around so I could mount the LED flat on the batteries taped the whole thing together with good ol' black tape (leaving small access to charge with 4.5 wallwart) Makes a decent little rechargable that lasts for a couple of weeks when turned off normally. I'm not sure what was wrong wiht the pack but the batteries are fine. I took apart the old battery found the same story and built another one. Replace the pack on my wifes phone and found the same story so I built another this time a headlamp w/8000mcd boy is that bright. Thinking about just buying the batter packs at $3 -$4 a piece since 4 AA NiMH run $10 - $15 the lights work great.
Recycle, REcycle, Recycle
Wildbill
« Last Edit: December 07, 2004, 01:41:29 PM by (unknown) »
Re: Cool little rechargable flashlights
« Reply #1 on: December 07, 2004, 03:59:24 PM »
your batteries will last longer if you use a resitor on your batt. pack..
plus your l.e.d.s wont burn out early..l.e.d.s dont like amps they overheat.
« Last Edit: December 07, 2004, 03:59:24 PM by hiker »
Peppyy
« Reply #2 on: December 07, 2004, 05:29:56 PM »
I am always amazed at how long a couple AA batteries will run a good bright led. I made up some 2 cell batt packs with the resistor built in. I use them for Halloween accent lighting and since we have a really small Christmas tree I hang them around to light the tree. A little bit of glittery stuff and a few colored led's makes it real pretty. I usually get a couple weeks out of a really cheep set of batts.
« Last Edit: December 07, 2004, 05:29:56 PM by Peppyy »
wildbill hickup
« Reply #3 on: December 08, 2004, 03:41:52 AM »
I do have a resistor in line 100ohm it think.
« Last Edit: December 08, 2004, 03:41:52 AM by wildbill hickup »
« Reply #4 on: December 08, 2004, 08:40:13 AM »
The kid is older and we didn't do a Jack-O-Lantern this year. Forgot until I got the trick or treat candy.
Grabbed a plastic pumpkin with the handle that she carried years ago for candy.
Threw in a homebrew LED flashlight with no reflector.
Hung it on a plant hook.
Really looked good.
Suprisingly, got lots of comments and questions like where did I buy it.
« Last Edit: December 08, 2004, 08:40:13 AM by ghurd »
zmoz
« Reply #5 on: December 08, 2004, 06:45:52 PM »
You can get 2000+mah NiMh AA batteries on ebay for under $1/peice. Much better than taking apart cell phone batteries.
« Last Edit: December 08, 2004, 06:45:52 PM by zmoz »
« Reply #6 on: December 08, 2004, 08:29:18 PM »
Hosfelt has 2100mah AAs for $1.95 everyday.
(I just hate ebay. I want to call a human and get my stuff!)
« Last Edit: December 08, 2004, 08:29:18 PM by ghurd »
