Did a search and did not find anything like this . . . .
Maybe for a good reason
Has anyone tried using a water weighted foundation for towers?
I am thinking this could be a relatively portable (as long as local water sources are available) tower base, that requires no concrete foundation, anchors nor guys.
The concept is still a bit fuzzy, but say a 8 feet by 8 feet by 4 feet deep "tank" of water weights somewhere north of 15,000 lbs. Using such a tank as the base of a tower could be pretty stout, but easily moveable by pulling the plug and draining the tank.
Anyway, that is some serious weight on the bottlom of a tower. If angle braces come up the corners, a tower could be mounted/built up from it, and have some serious side windload resistance, without a foundation or guywires.
I have not done any of the math, yet, but was curious if anyone has seen or read of any designs like that.
Have pondered some simplier versions, too. We have some water weights (used to hold water or test overhead cranes/hoists) They hold 250 gallons -- 2000 lbs. They could be used to "flip-up" a tower and hold it up-right, while full. To bring the tower down, drain the water, and tower lays back down.
The only downside that came to my mind was freezing. Down here (Texas) that did not seem too great a risk, but I follow many of "y'all" are in the Frozen North. (lucky you -- we had 100 degrees F on the first day of Fall)
Thanks, Phil
