So far I am just using the diary function to deal with my thoughts so as not to disrupt the main posting board. Having studied alternative and wind energy via observation and pondering, I am now ratcheting it up to real learning and application. Preface: there is too much in my mind to keep organized in print in less than many pages. So, I am just jumping in! (FYI: I try to think and write in outline form when possible, or at least use headings to identify line of thought).
GOALS AND OBJECTIVES
- Decrease my personal home energy costs (electric bill).
- Sell energy back into the grid (I was told by a PUC consultant that Texas requires 10kw minimum for grid tie).
- Be adequately self-sufficient on the infrequent occasions when the grid fails.
- Sell energy back into the grid, see my electric meter spin backwards, and have the electric co-op start mailing me checks.
- To be realistic in regards to #4.
- Wind my own high-wattage rotor without being afraid or overwhelmed.
- To express my creativity through all this.
- Perhaps start a wind-energy-related business and break free from my boring career in I.T. [for which I am currently uneployed - again].
PHILOSOPHIES AND VIEWPOINTS
At this stage I am obviously more full of questions than answers. So, I ask "what if" and "why not?"
I want to go the low-prop-speed/high-torque route and use gearing to run a shaft at speed where I can "easily" connect whatever rotor or generator head I want. As such, here is my first step. Maybe it takes me down the path to success, or maybe it is my first big mistake. But, good or bad, I did it. I bought a set of 4 big fat daddy blades (14' diameter on a 100 lb. metal hub):
Will need a sturdy tower indeed.
At first I thought I could simply buy a 10kw head at HarborFreight.com and start cranking. But, after doing a bunch of reading on this forum, me thinks again. With the expecation of widely-ranging shaft RPMs, it sounds like the homemade rotor is the way to go. (help me here, what is the proper term for the entire generator? Generator? Rotor? Head?).
If each blade is 33 lbs., then we're talking about a 230 lb. propjob ( oh my gosh! What am I thinking!?)
Originally I thought I would use the rear end out of an old Cadillac to mount the hub and initiate my drive train. But that sounds too monstrous and/or likely clumsy and off balance. So, maybe I should use a right angle gearbox to send a vertical driveshaft downward that I can harness at ground level. But then that defeats my original imaginings of a completely self-contained pivoting unit that merely "wires" electricity to my destination (this concept was in hopes of having a simplifed straight tail and then pivoting the top of the tower backwards against springs in case the winds got too heavy). Though I am creative and mechanically-inclined and capable, I am not at all the engineer that I percieve most of the others here to be. Thus, simpler is better for me.
Whether you agree or disagree, I welcome your feedback and ideas!
Come to think about it, that's probably enough for this post. I have some other thoughts that I will create a new entry for. - Stephen
