Author Topic: Controller Box Build  (Read 1033 times)
coldspot
« on: January 23, 2006, 05:21:11 PM »
For my WindMill.
I've been building a "Control Box", to hold all the things that are for this "illusion".
I started out with an old bathroom drawer, then found I had an old "Panel Box" door
that allmost covered it, I made it work to cover it by drilling new mnt holes.
But I didn't like the looks of the old mnt holes, so I drilled them out to hold other things, (Fuse holders, kill switch and breaker).
 I also didn't like the looks when mnting to bottom of box, so I raised stuff a couple inches off the bottom with sidemounted mounting spots.(Also to get closer to door with indicater LED on ChargeController, but will still need a optical tube to be able to see from outside, this will be installed later, when sure of componet placement).
 I would like to mount AmpMeter outside, but still thinking about.
 I know I when overboard on "IN" fuses, (Three). But why not?
Pictures to be posted later.
« Last Edit: January 23, 2006, 05:21:11 PM by (unknown) »
$0.02
coldspot
Re: Controller Box Build
« Reply #1 on: January 23, 2006, 01:41:03 PM »
The box
Wired
kill switch
« Last Edit: January 23, 2006, 01:41:03 PM by coldspot »
$0.02
coldspot
« Reply #2 on: January 23, 2006, 01:54:59 PM »
Only every other post working?
O-Well,
More info, (pic's)
fused on the "IN".
The KILL switch, pull to short. Is rated very high on AMPS!
« Last Edit: January 23, 2006, 01:54:59 PM by coldspot »
$0.02
coldspot
« Reply #3 on: January 24, 2006, 02:11:28 PM »
A question about wiring of Ampmeter?
Just on the pos before the fuses and controller?
My meter is from an old battery charger, 0-15 amp anolog gauge.
THANKS
« Last Edit: January 24, 2006, 02:11:28 PM by coldspot »
$0.02
coldspot
« Reply #4 on: January 29, 2006, 10:28:12 PM »
Control Box-
I picked up a Real Full Wave bridge Rectifier today, Shadio Rack # 276-1185
25 Amps 50 Volts.
I'll be mounting this to a old cpu heatsink, Intell slot A, these are about three times the size of a normal cpu heatsink, (2.23"X4.9", 5 each side outside fins 1.21"H, 10 center fins .9"H, 7 cutlines, longways).
 I might add a thermo sensor controlled old computer fan, but will wait to see if any heat is building-up first.
 I also picked-up a 12 VDC 25 Watt light bulb, will be adding to side of control Box in
a Outside porchlight type "Fancy" housing, as a "Dump" Load. If It isn't enough I might
add a lighter Heater type 12 VDC car heater and/or a "Block Heater", (Toyletta still dousn't need it, LOL).
pic's to follow.
l8r
« Last Edit: January 29, 2006, 10:28:12 PM by coldspot »
$0.02
