Author Topic: VAWT PHOTO's  (Read 1139 times)
ffoegw
VAWT PHOTO's
« on: March 12, 2006, 07:02:17 PM »
The hub which is made of 3" abs with a 4" end cap and 4" to 3" adapter.
Had to adapt because the 3" spare pipe I had did not have a big enough foot print to bolt on the bearings from a caster.
Here is the hub again with the spokes going through.
The holesthrough the 3" abs did not properly line up which worked out good as it created some friction to hold the 3/4" pvc spoke.
Also drilled holes though the pvc connector so that I could extend the spoke and change sails and sail designs without having to start from scratch.
Here's a sail made with 12" vinyl tile attached by a 3/4 inch pvc hinge to the 1/2 inch pvc frame.
pvc to vinyl glue is reallllllly solid!
This shows the holes in the sail where I can attach the elastic.
Drilled several so that I can experiment.
Does anyone know the name of the rope which does the same on a real sail boat?
attaches the sail to the end of the spar.
This photo show a pvc connect on the same hinge as the sail.
I did not glue this connector on because I hope to use it later to restrict the angle which the sail can travel through.
I will take and post some pictures of the entire thing assembled and deployed soon.
I think it's at least going to look very cool.
maybe I'll get my daughter to paint it for me.
Regards
Geoff Wright
ffoegw
« Last Edit: March 12, 2006, 07:02:17 PM by (unknown) »
ffoegw
Re: VAWT PHOTO's
« Reply #1 on: March 12, 2006, 12:41:52 PM »
Bolted the hub through the caster and onto the end of a 2x4.
Had to hammer in some wedges on the caster end and then epoxy the entire thing.
It looks a little messy but should be solid enough.
When the whole arrangement drys I will assemble, deploy and take some more pics.
Can you tell I'm getting a little anxious?
Need some wind.
Geoff
« Last Edit: March 12, 2006, 12:41:52 PM by ffoegw »
ffoegw
Re: VAWT PHOTO's
« Reply #2 on: March 13, 2006, 07:35:25 AM »
Went to Rona (hardware store) yesterday and saw some 4mm corrugated plastic sheet.
Very light, strong and cheap.
Woke up in the middle of the night and decided to replace the very heavy vinyl tile with the corrugated plastic.
Starting to feel better about this.
Geoff
« Last Edit: March 13, 2006, 07:35:25 AM by ffoegw »
spinner
Re: VAWT PHOTO's
« Reply #3 on: March 30, 2006, 09:44:33 AM »
love VAWTS of every kind
good luck with your project
thanx
spinner
« Last Edit: March 30, 2006, 09:44:33 AM by spinner »
