Well it's been up about 15 min now and so far
I can see that it's going to take a bit more wind
to turn this than it did to turn the "Ceiling Fan" blade
version.
The Ametek will have a "tiny-bit" more drag than before because
I've added a weather seal around the shaft to help protect
the gen from water on the shaft.
Also got a "Trim Blade" 5 blade version finished
for the "Servo" motor.
This would turn a bit in the very light breezes tonight
put the "Servo" motor will take a lot or RPM's to get any
power going. It would only show about 6 V DC with cordless Drill
spinning it. I checked when I had to see what way I wanted the
prop to turn to keep the wires as colored: Red = Pos with black = Neg.
This one is set-up as a counter clock-wise.
Trim being 2 1/4" wide full length of 26 1/4".
Being the Airplane wing type profile I tried to sand to
and then mounted to a flat surface they get about 19-20`
Pitch full length.
A the "Servo" motor is the only one I've got being 3/8" shaft
and that size being pretty easy to come by, with the plate,(Lock coller based)
I used being one of two I got last week,
I might go ahead and open this one up to 1/2", for use on the conversions.
