Author Topic: mini-gen done!  (Read 2543 times)
mini-gen done!
« on: April 17, 2006, 05:26:49 AM »
« Last Edit: April 17, 2006, 05:26:49 AM by (unknown) »
Re: mini-gen done!
« Reply #1 on: April 17, 2006, 02:15:31 PM »
This gen has 12 poles 9 coils and was really fun to make.
the magnets are 1/2"dia x 1/2".
coil data::
04-08-06 Program input Gauge= 20  Wire dia. = 0.0340 inches  ohms per foot 0.0101500
coil od = 1.000 coil width = 0.480 coilid= 0.450
Program output:
Final Diameter =                 0.994
 coil radius =                   0.275
Num turns per coil radius =      8.088
Number of turns per coil width = 14.118
total number of turns            114.187
wire length(feet)=               22.167
Single wound ohms per coil     0.224996 ohms
Total ohms for one phase                     (3 coils)       0.675 ohms
Delta single wound line to line resistance (2 coils / phase) 0.3000 ohms
above i was tweaking the blades for maximum rpm .
i got 327 rpm with  the fan on high.strangely i got  308 rpm with the fan on low.
on the  scope is a snapshot of the phase voltage ,set on 1V / div and 0.005mS / div.
the blades are 9 3/8 " from center to tip.
i plan on using this gen to charge 1.2 V NiMH rechargable batteries.
more on that later
« Last Edit: April 17, 2006, 02:15:31 PM by willib »
Re: mini-gen done!
« Reply #2 on: April 17, 2006, 02:32:49 PM »
sorry i ment to type 5mS / div.
also the delta line to line resistance is for two coils not three, i hadnt changed it since when i was going to put two coils per phase on the mini gen..
« Last Edit: April 17, 2006, 02:32:49 PM by willib »
Re: mini-gen done!
« Reply #3 on: April 17, 2006, 03:54:04 PM »
also the stator is assembled not cast
after i made the fiberglass sheets , i placed the coils over a template, and used resin to secure them in place , then i put the top piece on and used resin again,
its a very rigid stator, with very little resin used..
« Last Edit: April 17, 2006, 03:54:04 PM by willib »
behoof
Re: mini-gen done!
« Reply #4 on: April 17, 2006, 04:59:15 PM »
That is sooooo cool just simply awsome... what a neet project and thus that ol' statement... form WITH function
Thanks for the peek,
behoof
« Last Edit: April 17, 2006, 04:59:15 PM by behoof »
They're in the wire!!
gator
Re: mini-gen done!
« Reply #5 on: April 17, 2006, 05:44:37 PM »
Very, very cool!  I wish this stuff wasn't so far over my head.  I keep reading though and slowly getting supplies to start my wind gen.  Nice little project.  Keep sharing!
« Last Edit: April 17, 2006, 05:44:37 PM by gator »
harrie
Re: mini-gen done!
« Reply #6 on: April 17, 2006, 08:53:47 PM »
Hi Willib. Now that is a neat looking little turbine, I know even something that small takes a lot of work. Thanks for shareing, Harrie
« Last Edit: April 17, 2006, 08:53:47 PM by harrie »
Re: mini-gen done!
« Reply #7 on: April 17, 2006, 10:22:38 PM »
Many many thanks to all on this site without yous guys i dont think i could have finished it.
Below is the minigen charging a 1.2V battery. During this burst of wind it hit 80mA and ive seen it as high as 220mA.
i dont know where this wind ,but i'm ready for it..
 wow it just hit 316 mA.
« Last Edit: April 17, 2006, 10:22:38 PM by willib »
Re: mini-gen done!
« Reply #8 on: April 18, 2006, 07:12:06 PM »
I've graphed the data point i got last night
this is the data
 (mA) RPM - fan speed
  89 - 222 - low
 121 - 240 - med
 150 - 256 - high
these three points i got charging a 1.2V battery by the fan method.
this last point i got last night was 316mA and i plotted it to fit the curve.
http://www.otherpower.com/images/scimages/2965/line_3BDFB1B4.jpeg
« Last Edit: April 18, 2006, 07:12:06 PM by willib »
Re: mini-gen done!
« Reply #9 on: April 19, 2006, 01:11:42 AM »
SOoo off topic for this thread
I'm working in from reverse. Keep getting 140-ish turns per coil.
What do you come up with for this...
Dual 8/6, 3/4 square x 5/16" N45 neos, #20 wire, 1 meter blades, 5.5 TSR, 5.5MPH cut-in.
Rotors look like they will be 4.7" max.
« Last Edit: April 19, 2006, 01:11:42 AM by ghurd »
Re: mini-gen done!
« Reply #10 on: April 19, 2006, 02:10:09 AM »
still on the drawing board?
what i mean is you dont have any  test coil data?
« Last Edit: April 19, 2006, 02:10:09 AM by willib »
Re: mini-gen done!
« Reply #11 on: April 19, 2006, 10:21:07 AM »
No test coil. I'm pretty sure 140 per coil will get me in the right area.
Wondering how big the disks should be before I start in ruining the nice 4.75" speaker plates.
And if 140 turns of #20 per coil will fit with the stator 1/2" thick, given the 4.75" magnet disks.
Breaks my heart everytime I waste 2 pounds of wire, even worse when I ruin something like those rare speaker plates. :/
« Last Edit: April 19, 2006, 10:21:07 AM by ghurd »
Re: mini-gen done!
« Reply #12 on: April 19, 2006, 11:56:08 AM »
Those speaker plates are thick? enough to hold the neos on tightly?
the reason i ask is,there is a chance you could use 3 coils per phase IF, you dont mind the mags sticking off the end of the rotors a little bit?
like 0.152" ??
« Last Edit: April 19, 2006, 11:56:08 AM by willib »
Re: mini-gen done!
« Reply #13 on: April 19, 2006, 12:29:22 PM »
The plates are about 1/4" thick.
The 0.152" overhang is with 12 magnets? Seems like that would be kind of close.
« Last Edit: April 19, 2006, 12:29:22 PM by ghurd »
Re: mini-gen done!
« Reply #14 on: April 19, 2006, 12:50:12 PM »
"The 0.152" overhang is with 12 magnets?"
yes.
if you havnt bought the mags yet consider round ones ,
the distance between mags with 12 round neos centered on 04.304"dia is 0.378"
the distance between 12 square neos is 0.190" on the inside edge ,same dia.
http://www.otherpower.com/images/scimages/2965/ghurds_rotors_and_coils.JPG
« Last Edit: April 19, 2006, 12:50:12 PM by willib »
Re: mini-gen done!
« Reply #15 on: April 20, 2006, 05:08:18 AM »
Thanks!
Had these mags a long time.
« Last Edit: April 20, 2006, 05:08:18 AM by ghurd »
Re: mini-gen done!
« Reply #16 on: April 20, 2006, 08:59:15 PM »
On these blades , when the hub loosens up , or the wind is really strong , the blades trailing edge tends to move  forward , (into the wind) ,which way should i move the pivot point ,(mount)  and more importantly why.
(you must justify your anwser)
« Last Edit: April 20, 2006, 08:59:15 PM by willib »
Re: mini-gen done!
« Reply #17 on: April 21, 2006, 07:19:50 AM »
Flatter?  Because the blades are trying to go faster to the point where air resistance is forcing them to a lower angle of attack?
I don't know, but its interesting that happens.
« Last Edit: April 21, 2006, 07:19:50 AM by ghurd »
Re: mini-gen done!
« Reply #18 on: April 24, 2006, 02:24:37 AM »
Yes , i thought so..
« Last Edit: April 24, 2006, 02:24:37 AM by willib »
Re: mini-gen done!
« Reply #19 on: April 25, 2006, 01:34:08 PM »
i was testing the minigen , and got 1A DC from it , turning it by hand @ 250rpm.
just need a bigger set of blades for it  i suppose .
no problem there.
« Last Edit: April 25, 2006, 01:34:08 PM by willib »
