Author Topic: 3.5 foot dia. tsr 6 blade mold  (Read 1626 times)
« on: June 20, 2006, 04:42:28 PM »
below is a close up of the last half which i finished last night.(file size is 66 kb )
http://www.otherpower.com/images/scimages/2965/IM002142.JPG 66Kb
below is looking into each half of the soon to be mold
below is a perspective pic of the two mold halves next to the blade
next step is to build an enclosure for the mold
« Last Edit: June 20, 2006, 04:42:28 PM by (unknown) »
theTinker
Re: 3.5 foot dia. tsr 6 blade mold
« Reply #1 on: June 20, 2006, 04:30:28 PM »
they look very nicely done. i get the impression that kinda of blade making takes alot of precision and patience. how long does it take you to make a full blade? been hollow they must be light as feathers comparing to wood.
« Last Edit: June 20, 2006, 04:30:28 PM by theTinker »
« Reply #2 on: June 20, 2006, 04:56:19 PM »
this is a mold for blades , that i'm going to make
i'm going to fill the hole with canned foam and glass and epoxy .
i found the perfect foam ,it dries hard as a rock yet is very light , and strong..
its taken weeks to get this far.
, but after i get the mold done i should be able to make a set of three in a several  hours depending on the temp , and the curing time needed for the foam..
« Last Edit: June 20, 2006, 04:56:19 PM by willib »
  • Country: aq
  • Village idiot
« Reply #3 on: June 20, 2006, 06:09:11 PM »
You got an A for perseverance Willib.... well done.
..........oztules
« Last Edit: June 20, 2006, 06:09:11 PM by oztules »
coldspot
« Reply #4 on: June 20, 2006, 07:35:52 PM »
Very Very Nice work!!!
So.......
We should be able oder us, (your friends here @ otherpower)
some  "3.5' Dia tsr 6" Foam blades .
In maybe a couple more months??????????
lol
When and What
Let us know
« Last Edit: June 20, 2006, 07:35:52 PM by coldspot »
$0.02
« Reply #5 on: June 20, 2006, 11:11:24 PM »
granted i've been working on foam blades for some time , but its been just 4 weeks & 4 days since these blades were potential wall insulation on the store shelf ( till i rescued them).
« Last Edit: June 20, 2006, 11:11:24 PM by willib »
SamoaPower
« Reply #6 on: June 21, 2006, 02:38:15 PM »
Congrats! Looks like you've had some success.
There is a point I have trouble understanding. You claim a TSR of 6 and yet your own measurements of an unloaded RPM of 285 in 13-15 mph of wind doesn't jive.
Those measurements indicate an unloaded TSR of 2.5. It's likely that when loaded with a matched load the TSR will drop to less than 2.
Am I missing something here?
« Last Edit: June 21, 2006, 02:38:15 PM by SamoaPower »
« Reply #7 on: June 21, 2006, 05:38:51 PM »
the ones i was referring to in this post were the larger ones
http://www.fieldlines.com/comments/2006/5/14/84437/3687?pid=11#13
which are just shy of 8 feet dia at the  moment.
the photo at the beginning of the thread
http://www.otherpower.com/images/scimages/2965/IM002082.JPG
is an old one i've since added 30 inches to the dia.
i have one more 5 inch section to add to all three blades
« Last Edit: June 21, 2006, 05:38:51 PM by willib »
« Reply #8 on: June 23, 2006, 10:58:00 PM »
i've been doing a lot of thinking since my last post , not much work has gotten done .
but i think the best way to accomplish what i need to do is , to do each half separately , this way i would be able assemble it, rather than have it as a mold (top and bottom ).
my first job after high school was making plastic bottle molds and trimmer machines for plastic bottles, anyway i can envision what will happen if for some reason i cant get the mold apart, after i've layed in the epoxy and glass and the foam.
lots o' cursing , and a destroyed mold in the end.
so i think i'm going to lay the epoxy & the glass to each half and assemble the two halves afterward. the safe way is usually the best i think..
« Last Edit: June 23, 2006, 10:58:00 PM by willib »
« Reply #9 on: June 25, 2006, 10:53:48 AM »
I've got the leading side curing at the moment .
What you are looking at is the inside of the leading side .
the outside of the leading side is going to be a lot smoother .
i spent days thinking of how i was going to hold the mold , and i even made a cradle for it , but as you can see i didnt use it.
the convienence of being able to move it around while i was applying epoxy won out over the mold holder..
« Last Edit: June 25, 2006, 10:53:48 AM by willib »
it came out real smooth ! ! !
« Reply #10 on: June 25, 2006, 12:53:33 PM »
i think it came out real nice!!
« Last Edit: June 25, 2006, 12:53:33 PM by willib »
  • Country: aq
  • Village idiot
Re: it came out real smooth ! ! !
« Reply #11 on: June 25, 2006, 05:13:22 PM »
Is that the airfoil (convex top half of the wing) or is it a pic of the complete wing from the convex side.
If it doesn't work, at least it'll look good (after a haircut)............oztules
« Last Edit: June 25, 2006, 05:13:22 PM by oztules »
« Reply #12 on: June 25, 2006, 09:39:31 PM »
Hi Oztules, its the outside of the leading half ,that faces the wind.
No its not complete yet , hence the strands..
it is just a shell of its future self :)
« Last Edit: June 25, 2006, 09:39:31 PM by willib »
« Reply #13 on: June 26, 2006, 12:23:37 PM »
i did another one of the outside of the leading side , but this time i used polyester resin. it came out ok , but the poly resin is not as clear as the epoxy resin.
and i'm soo glad i made the mold like i did , because i think there is no way the mold would have come apart if i had made it as one piece .
the above airfoil half  is really a little more yellowish looking without the camera flash .and not as professional looking as the epoxy resin. i hav'nt tried a gel coat yet hmmm that might look nice, with a white jel coat, and a red jel coat on the tips..
« Last Edit: June 26, 2006, 12:23:37 PM by willib »
