Author Topic: Tubes  (Read 913 times)
Tubes
« on: June 28, 2006, 02:04:50 AM »
Three of these came out of a really old amplifier .
the speaker had an electro magnet.
not even a permenent magnet !!
i'm not up on my tubes but these are pretty old .
three have only 4 pins
« Last Edit: June 28, 2006, 02:04:50 AM by (unknown) »
terry5732
Re: Tubes
« Reply #1 on: June 27, 2006, 08:36:12 PM »
The speaker probably had an iron magnet that lost it's magnetism.
Check the filaments for continuity. The filament connections are the two thickest pins. Should be about 3/4 ohm. If open they are of no use. #45s are sought after if good.
« Last Edit: June 27, 2006, 08:36:12 PM by terry5732 »
Re: Tubes
« Reply #2 on: June 27, 2006, 08:39:43 PM »
Hi Willib.
Well your on your way to building a singl ended or push pull "45" amp. These are open filliment triodes. A very common audio output tube of the late thirties early 40s.
They are still used today in very high end amps. I think the Chineez and Rusians are still making these?
You can get maybe 10 to 15 watts out of a pair.
« Last Edit: June 27, 2006, 08:39:43 PM by Jerry »
Re: Tubes
« Reply #3 on: June 27, 2006, 08:40:17 PM »
the speaker had what looked to be 1/2" thick steel  "U" shaped base , with about 4" dia. windings around it..
« Last Edit: June 27, 2006, 08:40:17 PM by willib »
Re: Tubes
« Reply #4 on: June 27, 2006, 08:46:06 PM »
The amp unit had at least five maybe six huge transformers on it .
it must have weighed 50 pounds easy.
« Last Edit: June 27, 2006, 08:46:06 PM by willib »
