Author Topic: magnetic flux (gauss) meter  (Read 11338 times)
« on: August 13, 2006, 05:57:37 AM »
I thought i would do a little investigating today .
Hall sensors as i found out can be found in old CD rom drive motors
here is three that i got out of one motor
on the right  is my trusty Weller with the attachment that i used to get them off
http://www.rcgroups.com/forums/showthread.php?t=307133
the above site has all the info on how to make a gauss meter
i want to  use it to measure current for my data logger
Hall switches are slightly different , in that they switch from plus to minus as the magnetic field of a rotating alternator switches.
i've allready used a hall switch to measure RPMs on my test bed , hall switches can be found in pc powersupply fans.
so the hall switches can be used measure turbine RPM as well as wind speed , by using the same fan with the armature removed , and keeping the fan part (with the magnets) and the circuit board intact
the goal is to assemble all the sensors needed to record data from a windmill
the hall sensor will output a voltage proportional to the current, thats the plan anyway.
it only took about five mins to get the motor out of a CD drive, the rotor with mags just pulls off , the tool i used to get them off ,is some 17 ga wire wrapped around a soldering iron
some other links i came across
http://my.execpc.com/~rhoadley/magmeter.htm
and a Dutch version
http://www.modelbouwforum.nl/phpBB2/viewtopic.php?t=7834
« Last Edit: August 13, 2006, 05:57:37 AM by (unknown) »
steeolico
Re: magnetic flux (gauss) meter
« Reply #1 on: August 13, 2006, 01:06:21 AM »
Molto interessante Willib!
A lot interesting Willib!
« Last Edit: August 13, 2006, 01:06:21 AM by steeolico »
jimovonz
« Reply #2 on: August 13, 2006, 01:45:15 AM »
« Last Edit: August 13, 2006, 01:45:15 AM by jimovonz »
« Reply #3 on: August 13, 2006, 09:42:34 AM »
Thanks i'm just trying to build on Warske's work
as Jim pointed out it can be found at
if anyone has a free hour , its worth a read , the discussion is captivating and the links are awesome !
it took about five mins to get this far
« Last Edit: August 13, 2006, 09:42:34 AM by willib »
« Reply #4 on: August 13, 2006, 09:51:41 AM »
Is that where you got your sensors from?
a cd drive ?
thats  them at six , four thirty , and three o'clock.
Warske peeled the metal off the back of the circuit board , but i saw no need to because the chips were allready visible , and accessable.
« Last Edit: August 13, 2006, 09:51:41 AM by willib »
Preperations and soldering
« Reply #5 on: August 13, 2006, 11:57:05 AM »
i've tinned the wires in preparation for soldering
and put the chip in a clamp to hold it and soak up some heat just in case
all the wires went on smoothly
one came off so i had to redo it
all wires are on
time for fun
« Last Edit: August 13, 2006, 11:57:05 AM by willib »
hall sensor pinout and schematic
« Reply #6 on: August 13, 2006, 12:09:54 PM »
following warske this is the pin out and a schematic
« Last Edit: August 13, 2006, 12:09:54 PM by willib »
scope output
« Reply #7 on: August 13, 2006, 01:42:13 PM »
i was hopeing this would be the case
you could also use the sensor to measure RPM if necessary
sorry for the blurry pic but its hard to snap a shot when your turning the testbed.
with a 1.2V NiMH battery hooked up to the sensor , the scope is set at .5V per div
the reading from the sensor is about .6v peak ,  with the sensor in the path of the magnets
« Last Edit: August 13, 2006, 01:42:13 PM by willib »
stephent
« Reply #8 on: August 13, 2006, 01:52:14 PM »
Might be able to use one as a currant sensing device too.
Just watch which end is pointing to the mag or circuit.
The Hall's from the CD are nice and your project has started me thinking about Nando's controller using one as a currant sensing device for diversion purposes, maybe.
Thanks for the ideas....
« Last Edit: August 13, 2006, 01:52:14 PM by stephent »
« Reply #9 on: August 13, 2006, 03:46:33 PM »
I'd save that stator-thingy & rotor too. If the RC guys can convert it to motors, that same conversion should work as an alternator too. A mini windgenerator perhaps?
Ghurd, you read this?
« Last Edit: August 13, 2006, 03:46:33 PM by dinges »
« Reply #10 on: August 13, 2006, 06:08:12 PM »
Very low volts.  Half will not light an LED.
Sometimes a motor is better left as a motor.
« Last Edit: August 13, 2006, 06:08:12 PM by ghurd »
current & RPM at the same time
« Reply #11 on: August 13, 2006, 07:43:35 PM »
Thanks for your comments
Below is the sensor between the magnets
this is the setup , thats it on the right at the end of the wires, its powered by a single NiMH AA battery
i  was just trying to get a reading off the coil here , i quess i need more turns
a close up of the sensor, i sure wish i could get better closeups , maybe if i use a magnifying glass they would come out better
below is the setup that really worked well , its similar , if not exactly what Jim did , except that i've put it in the line comming from the test coil ,i have twelve or so turns wrapped around a ferrite toroid , with a slot cut in it and the sensor inserted in the opening
 and got great results , at low RPM the wave looks like a sine wave with a peak of .2V , at higher RPM i've had  .4V peak out of it , so the wave grows with an increase in current , and one could also measure RPM because its a sine wave
« Last Edit: August 13, 2006, 07:43:35 PM by willib »
« Reply #12 on: August 13, 2006, 09:24:07 PM »
yes but if you could spin it fast enough it would put out more power, also those RC people do a really , really cool job of putting small neos in place of the ceramic ones that come in the stock motor.
for the stator that i have , nine coils ,they would put 12 tiny neos , and make a nice three phase motor , their efficiency is up there too , because they also rewind their stators , and they put some amps into those little motors and crank them up to around  10000 RPM , they use them for helicopters and planes and are allways talking torque and efficency .
« Last Edit: August 13, 2006, 09:24:07 PM by willib »
« Reply #13 on: August 13, 2006, 09:57:11 PM »
I'm on the hunt for one of those DLT tape drives.
« Last Edit: August 13, 2006, 09:57:11 PM by ghurd »
kitno455
Re: current & RPM at the same time
« Reply #14 on: August 14, 2006, 10:22:31 AM »
cool willi- see if your camera has a 'macro' mode- the icon often looks like a tulip or a mountain. set to 'tulip' mode, you might get better closeups
allan
« Last Edit: August 14, 2006, 10:22:31 AM by kitno455 »
« Reply #15 on: August 14, 2006, 12:19:48 PM »
sorry no such luck, it is a HP 315 , hmmm it does have a digital zoom ,2.5X maybe i'll try that
« Last Edit: August 14, 2006, 12:19:48 PM by willib »
« Reply #16 on: August 14, 2006, 12:59:34 PM »
ok Dave i have assembled some devices to get this done.
wind speed - a pc fan with the armature removed.( hall switch)
windmill current and rpm - hall sensor.( amplitude gives current from the windmill , frequency gives RPM)
battery voltage - simple PIC input
all tied into the 16877A which has 8 A/D inputs
OK GO !
kidding ...
the pic also has two built in PWM modules
although i havnt tried the serial port it has one built in , which i understand can be hooked directly into the hyperterminal of windows.
« Last Edit: August 14, 2006, 12:59:34 PM by willib »
« Reply #17 on: August 18, 2006, 01:45:28 AM »
I did some work on the software for the programmer for the pic16f877a
i had to redo a bit of it , because i wrote it for another chip, and lost the newer version when i shorted the keyboard .
it's sort of a rush when you are able to change a location in the memory of the chip. a little more work and i'll be able to start programming it.
i havnt checked the data sheet yet but i think the F877a & the F88 are identical (programming wise), if they are, then  i can also do the F88 with the same version of software , which means i will be able to boost the pwm on the F88 to a more reasonable value , say 30 or 40 Khz
« Last Edit: August 18, 2006, 01:45:28 AM by willib »
The programmer is finished !
« Reply #18 on: August 20, 2006, 07:16:41 AM »
Yay the programmer is done !!
Now i can alter the PWM program to run at a higher frequency.
i just need to look over the manuals, and try to remember how to do it
the programmer was different, because i wrote it , and it can now successfully put a  program into a chip again
and i can start working on the program for the Data Logger.
« Last Edit: August 20, 2006, 07:16:41 AM by willib »
