Author Topic: Measure RPM with Cadence  (Read 2208 times)
wayne
« on: October 04, 2006, 05:15:24 PM »
Hi
Just thought I would pass this on with the new cycling computer's that have Cadence built in. what it does it measures your pedal RPM's, so anyone want a easy digital RPM read out for there turbine here is is. About 20 bucks
enjoy
wayne
« Last Edit: October 04, 2006, 05:15:24 PM by (unknown) »
harrie
Re: Measure RPM with Cadence
« Reply #1 on: October 04, 2006, 08:28:57 PM »
HI Wayne, how does it accomplish the readout?, Not sure what Cadence means? Thanks Harrie
« Last Edit: October 04, 2006, 08:28:57 PM by harrie »
disaray1
« Reply #2 on: October 05, 2006, 06:49:26 AM »
 Hi Harrie...The cadence is the rpm of the crankset (big gear with pedals) and uses a small magnetic pickup (some are wireless transponders) mounted to the frame and a small magnet attached to the crankset, so the two pass in close proximity every rev. The speedo works the same way, and is adjustable for wheel size, and calculates km/h per rpm for a given wheel size.
 Wayne, have you tested this unit to see if it has a max cadence rpm?
 Thanks, and bike on.
   disaray1
« Last Edit: October 05, 2006, 06:49:26 AM by disaray1 »
wayne
« Reply #3 on: October 05, 2006, 08:10:40 AM »
Disary1
I have only had it up to 200 RPM but tonight will spin it up too the max on my lathe, good question. So far I really like mine for testing, nice and easy
wayne
« Last Edit: October 05, 2006, 08:10:40 AM by wayne »
wayne
« Reply #4 on: October 06, 2006, 08:10:28 AM »
On my belt driven Lathe did a test
Lathe Setting        Computer
  1.                    640 RPM
  2.                    146 RPM
So I think it would read up to 999, I didn't want to magnet to fly off but should be no problem.
Wayne
« Last Edit: October 06, 2006, 08:10:28 AM by wayne »
Just measure RPM with the Speedometer
« Reply #5 on: October 06, 2006, 08:29:33 AM »
Another option if cadence is too low.
Set it to Km/H. Set the wheel circumference to 166.7cm.
The Km/H is multiplied by 10 to get the RPMs.
ie: 32.8 Km/H on the speedometer is 328 RPMs.
(quick math, but I think thats right)
CatEye is a higher end brand, Mity8 is one of their lower cost units. This model is listed as 4Km/H min, 105Km/H max.  So it should read from 40 to 1050 RPM.
I stretched the wire to 30+ feet on a Mity8 and it worked fine as a speedometer.
« Last Edit: October 06, 2006, 08:29:33 AM by ghurd »
disaray1
« Reply #6 on: October 06, 2006, 12:49:55 PM »
 Thanks Wayne and Mr.G...these things are good to know. ;)
 disaray1
« Last Edit: October 06, 2006, 12:49:55 PM by disaray1 »
