Well Bigkahoona,
As you are aware, I support Kurt on this one that a new stator is in order....... however, I see a stubborn streak here, and it is a bit like me when I have got a bone to chew on.
If you insist on using that stator, I can only offer this way out. (I have dabbled in higher power pwm, and it is a long learning curve for me.... still a long way to go and failure is always close at hand). So for a very reliable PWM, use xt power supplies. A quick 45min rewire will produce a free (I assume you will get the psu 's from XT's for free for sure), 150-200w unit which you have complete control over.
For 5 phase with your existing relay switching arrangement on your desk you can switch in or out as many as you wish... use the inhibit pin on the tl494 for this function. You can switch between 110v and 240v on each supply (switch is on the back and you can use your multitude of computer controlled relays to make or break the contact)), you can establish whatever current per psu you want (between 0-15A), and can set the upper voltage to whatever you please <16v preferably)
It will require about 45mins work per unit, and it will be stable, controllable, and in your setup, the cheapest to fiddle with for the best results. I guess you could hook your computer up to a wind speed indicator and have a mppt system too.) A bank of 10 of these would give you a varied load for the mill at high impedance.... if you wanted to get creative you could set the currents differently on them all and switch them in sequentually.
At the risk of hijacking your thread, here is one in operation. This one is driving a 12v coffe maker at moderate load 8v@10A... the trimpot sets A max.
![](http://www.otherpower.com/images/scimages/5171/setup.jpg)
By turning the trimpot up in this picture, we control the output current, the voltage rises until the new max current is drawn by the load.
![](http://www.otherpower.com/images/scimages/5171/component.jpg)
Here it is turned up to 15A, the voltage has risen to a point where 15A is absorbed by the load (coffee maker) and the voltage happens to be 14v You can set the voltage hardwired (as I have at 14.5,) or the current...or both which ever value reaches it's max first controls the output... ie if I turn up the amps even more, only a small current change would occur as 14.5v voltage limit (I have set by fixed resistor) would then limit the output, not the curent any more.
![](http://www.otherpower.com/images/scimages/5171/15A_14v.jpg)
Now as your lower power winds are in operation you can turn on /off different psu's set at different current levels (if you wish to utilise that huge array of relay drivers on your desk), simply connect to pin4 of tl494 to turn on the supplies, this means no heavy dc switching in the relays only a few milliamps
So using 4 resistors, a trim pot a small capacitor a piece of wire (for the current sense 2"long) and a pair of side cutters you can achieve what you want.
oh and here is the current sense
![](http://www.otherpower.com/images/scimages/5171/current_sense.jpg)
It would be compact, reliable controllable and scalable.... and basically free..... pretty messy I admit too )
Personally I'd build a new stator, but a next to free solution is available to you.... only take a lot of desk space and your time..... I figure this will be a whole lot faster than designing a multi kilowatt design from scratch.
Plenty of silly ideas left to play with over here..
Guess you could tell that though..
.........oztules
