Author Topic: Junkyard trip  (Read 1907 times)
RobC
Junkyard trip
« on: November 19, 2007, 04:44:21 AM »
We found a few items at the junkyard and and thought we would give all of you a  chance to guess what or where they came from.
I hope they will  be wind generators in a year or two. RobC
« Last Edit: November 19, 2007, 04:44:21 AM by (unknown) »
RobC
Re: Junkyard trip
« Reply #1 on: November 19, 2007, 11:09:17 AM »
I should probably have told you that both sets of stators and rotors came out of same aluminum case.
« Last Edit: November 19, 2007, 11:09:17 AM by RobC »
drdongle
Re: Junkyard trip
« Reply #2 on: November 19, 2007, 04:09:43 PM »
Any idea what it came out of? any name plate data?
« Last Edit: November 19, 2007, 04:09:43 PM by drdongle »
Re: Junkyard trip
« Reply #3 on: November 19, 2007, 04:41:03 PM »
Well i will post a guess.
 A smallish gridtied turbine.The smaller unit would maybe used for controls and the other to feed the grid.
« Last Edit: November 19, 2007, 04:41:03 PM by vawtman »
RobC
Re: Junkyard trip
« Reply #4 on: November 19, 2007, 05:12:59 PM »
These parts came out of a Toyota Prius hybrid. The small pink stator came out of the front of the main power unit next to the motor and the large stator came out of the other end of the unit.
« Last Edit: November 19, 2007, 05:12:59 PM by RobC »
Re: Junkyard trip
« Reply #5 on: November 19, 2007, 05:17:13 PM »
Darn that was the first thought i had.
« Last Edit: November 19, 2007, 05:17:13 PM by vawtman »
BT Humble
Re: Junkyard trip
« Reply #6 on: November 19, 2007, 07:04:14 PM »
I had no idea that the Prius came with a rock hammer as standard equipment! ;-)
BTH
« Last Edit: November 19, 2007, 07:04:14 PM by BT Humble »
Re: Junkyard trip
« Reply #7 on: November 19, 2007, 07:43:34 PM »
I bet its for power-steering, or A/C or some other auxiliary system.
Yes,yes,  nice rock hammer by the way, bet that was helpful for prying casings apart.
I fixed my spellchecker. :)
« Last Edit: November 19, 2007, 07:43:34 PM by JW »
harrie
Re: Junkyard trip
« Reply #8 on: November 19, 2007, 08:40:33 PM »
I have a prius, thanks for giving me a look at whats under the hood, you sure cant see much by trying to look into the engine compartment. interesting!!
« Last Edit: November 19, 2007, 08:40:33 PM by harrie »
RobC
Re: Junkyard trip
« Reply #9 on: November 19, 2007, 09:34:47 PM »
Well BT you never know on these new high tech auto's when you might have to lift the hood and tap on something. And if your really angry use the pointy end of the hammer. RobC
« Last Edit: November 19, 2007, 09:34:47 PM by RobC »
Kevin L
Re: Junkyard trip
« Reply #10 on: November 20, 2007, 04:58:43 PM »
Regen braking system.  Slows the car down while charging the battery bank.
« Last Edit: November 20, 2007, 04:58:43 PM by Kevin L »
