Severel recent forum posts have dealt with Ametek 30 tape drive motors using PVC blades. I fly an Ametek 30 with a two bladed wooden prop which has performed quite well. Perhaps this information may be of use to those having problems with PVC blades. Following is a picture of my unit on it's storage stand in my garage. Unfortunately, political issues prevent me from flying it full time.
The prop is 48" (1219mm) in diameter with a set angle of approximately 4 degrees, giving a TSR of about 5.5. This is from Hugh's blade design tutorial, freely available in a pdf format on the Scoraigwind website. The wood is a piece of straight grained nominal 1x4 fir (19mm x 89mm actual), which I got from Home Depot for $2.35 USD. It tapers from 3.5" (89mm) at the root to 2.625" (67mm) at the tip. The thickness at the tip is approximately 5/16" (8mm).
There is no twist to this prop. I don't believe twist is really necessary in a prop of this small size, as it spins up quit nicely at about 9 - 10 mph (4 - 4.4 m/s) which is about the cut-in speed for this motor. I think my next prop, assuming I'll need one, will be a TSR of 5 to extend the range up a bit.
I bought the lumber for this prop a Saturday afternoon and had it completed by the next afternoon, using only a couple of homeowner's wood chisels, a small block plane, and a palm sander to complete it.
One word of caution. After reading numerous posts about vibration issues with two-bladed props, I was absolutely meticulous with balancing. I used a small plastic cone that pivots on a plastic spike I had for balancing lawn mower blades. This device is available in the lawn & garden section of the hardware store. The blade shows absolutely no vibration issues from imbalance.
Regards,
Kevin
"At what point does intellectual curiosity become a thought-crime" ...unknown
