Author Topic: Newer more efficient gas furnace have much smaller blower motors?  (Read 2739 times)
  I couldn't help thinking if only I had a smaller
motor that ran the furnace blower...I could run
the furnace with a lot less current.
  The furnace that I have is a gas furnace 40
years old, originally it had a 1/5 HP. motor
It now has  a 1/4 hp.
driving a squirrel cage blower belt drive....
It has an adjustable ratio pulley on the motor
that can be adjusted from 3/4 inch to 3 inch
the blower has a 6 inch pulley.
   At the present time it is adjusted to 2 1/2
inches.
    I experimented with it one time...it can be
switched to CAC (Constant Air Circulation) then
I adjusted the variable ratio pulley to  1 inch.
    I liked it but I was concerned that it used
too much electricity that way. It was quiet at
that slow of a speed but the wife could barely
hear it and so she didn't like it.
    Anyway I would like to know what size motors
they have on the newer efficiency furnaces.
    This furnace heats an 864 sq.ft. house
( 24 X 36 ft.)
     Mainly I want to know the smallest size
inverter I would need if I had a newer furnace
installed. I'm getting a 700 watt inverter from
Sears ...If that is big enough my  requesition
slip is more likely to be approved by the 'Boss'
Thanks for any help
« Last Edit: March 11, 2008, 01:15:19 AM by (unknown) »
Re: Newer more efficient gas furnace have much sma
« Reply #1 on: March 10, 2008, 08:06:19 PM »
Gee, Norm;
Why not go direct off batteries?
Just wondering if you could set up a bunch of muffin fans in a flat pack to push air around?
Some are very efficient, quiet and cheap. Run off DC so no need to run an inverter and all the issues with that.
Another option might be cooling fans for vehicles? They usually suck at efficiency, I think, however.
Just thinking out loud.
« Last Edit: March 10, 2008, 08:06:19 PM by TomW »
kurt
    • website
« Reply #2 on: March 10, 2008, 09:50:27 PM »
newer furnaces have multi speed usually 3 motors of about 1/2 hp plus a 1/8 hp or so vent blower motor plus glow bar ignition that draws 300-400 watts for a minute or so every time the burner starts some models use spark pilot ignition and that uses allot less power but most use the glow bar these days.... o and when you find that your furnace don't work on a cold winter night it is usually that glow bar they are not very reliable.
« Last Edit: March 10, 2008, 09:50:27 PM by kurt »
scottsAI
Re: Newer gas furnace have smaller blower motors.
« Reply #3 on: March 10, 2008, 10:40:38 PM »
Hello Norm,
Newer furnace can have variable speed blower motors. (many not just 3 speeds)
Can be set for Constant Air Circulation using about 40watts.
The burners are also variable BTU output.
When the burner is on the blower speed goes up depending on how much heat is needed. Top speed fan blower power is around 200watts. Make sure the blower has actual air foil bladed blower fan. Many have bent metal, which use about 30% more power for the same air speed.
Of course depending on the manufacture the above numbers can be all over the map, the above represent the best I could find. A furnace with these features cost more than one without... so you will have to decide what is the lowest system cost for you. Hopefully your in the market for a new furnace? Otherwise this is another system expense.
I would rather look at solar heating than a gas furnace...
Or use a gas tankless hotwater with an A frame for heating and hotwater, just might be overall lower system cost and much easier to add solar heating in the future. Efficiency is almost as good, the tankless hotwater is much better than most.
Have fun,
Scott.
« Last Edit: March 10, 2008, 10:40:38 PM by scottsAI »
« Reply #4 on: March 10, 2008, 10:41:30 PM »
A fresh new filter makes a big change in
the blower power needed too.
I wouldn't be comfortable with 700W from Sears.
Might consider the 100AH near the furnace,
charged by the van with long jumper cables?
Just for that once ever couple years.
« Last Edit: March 10, 2008, 10:41:30 PM by ghurd »
Chagrin
« Reply #5 on: March 11, 2008, 02:08:52 AM »
Yeah the newer ones are DC motors. Something to look forward to.
Working as an HVAC installer must be like used motor heaven.
« Last Edit: March 11, 2008, 02:08:52 AM by Chagrin »
« Reply #6 on: March 11, 2008, 07:35:15 AM »
Yes it's from Sears and it's a clearance item,
so that should tell savvy people something ..Eh?
« Last Edit: March 11, 2008, 07:35:15 AM by Norm »
« Reply #7 on: March 11, 2008, 07:53:06 AM »
Yes I have 2 openings in the bonnet where the
return air goes....one in the hallway that is
about 10 x 18 inches....just had a thought about
using 2 window fans blowing into the hallway
from the front room and closing the utility and
bedroom doors.
Make a special door to fit the 2 fans into and
put in the hallway door opening into the front
room, the 225.....max 400 watt inverter
runs one fan that I know of...it could perhaps
run 2?
 Could possibly work....Thanks for the start in
the right direction..It would be doable even for
me....LOL !
« Last Edit: March 11, 2008, 07:53:06 AM by Norm »
Re: Newer more maller blower motors?
« Reply #8 on: March 11, 2008, 08:00:35 AM »
Thanks Guys info from all of you has been very
helpful.
BTW The swing project is still an ongoing project
even tho its impossible to swing right now with
snow drifts up over the seats!....too much drag !
     LOL !!
« Last Edit: March 11, 2008, 08:00:35 AM by Norm »
