I couldn't help thinking if only I had a smaller
motor that ran the furnace blower...I could run
the furnace with a lot less current.
The furnace that I have is a gas furnace 40
years old, originally it had a 1/5 HP. motor
It now has a 1/4 hp.
driving a squirrel cage blower belt drive....
It has an adjustable ratio pulley on the motor
that can be adjusted from 3/4 inch to 3 inch
the blower has a 6 inch pulley.
At the present time it is adjusted to 2 1/2
inches.
I experimented with it one time...it can be
switched to CAC (Constant Air Circulation) then
I adjusted the variable ratio pulley to 1 inch.
I liked it but I was concerned that it used
too much electricity that way. It was quiet at
that slow of a speed but the wife could barely
hear it and so she didn't like it.
Anyway I would like to know what size motors
they have on the newer efficiency furnaces.
This furnace heats an 864 sq.ft. house
( 24 X 36 ft.)
Mainly I want to know the smallest size
inverter I would need if I had a newer furnace
installed. I'm getting a 700 watt inverter from
Sears ...If that is big enough my requesition
slip is more likely to be approved by the 'Boss'
Thanks for any help
