I've never done a laithe test on the Garbogen.
It is a 1 hp motor conversion. I havn't had a Garbogen PMA for a while so I through one together.
This PMA is a 2 phase. It was a single phase motor.
It's set up for 12 volt. I did a laithe test on this one at 430 rpm.
No load at 430 rpm the fluke says 24.07 volts dc.
I hope to do more testing this week.
In the real world bench test I use an infered RPM meter, 6 each 220 amp/hr golf cart batteries configured as 12 volt, 2.5 HP varyable speed 100 lb DC motor as prime driver, 5 KW varyac to control input voltage to the fullwave bridge and 4,000 UF/400 volt cap bank that supplies dc to the motor, 2 infered thermometers, a Fluke true RMS volt meter, a realy nice 60 amp analog amp meter, a 400 amp digital amp meter.
I wish we had your PMA here for some good bench testing.
I'll be testing the Garbogen, Hughs 4 ft pma and the 14-11 when I get it done.
Heres a blury picture of the Garbogen PMA and the laithe.
Here a picture of the Fluke measuring no load voltage.
These 2 machines should be close in preformace scince there both 1 hp?
